The Preference for Direct Radiators
Old 16th December 2018, 10:40 AM   #111
AllenB is offline AllenB  Australia
Originally Posted by Bicicletta View Post
Even more: people like dome tweeters, little cones and little baffles far away the walls. I have no comparison: I never heard a quality horn system.
I think about it this way: direct radiators typically fit a half space baffle, and this is arbitrary.. it doesn't fit the room directly. If you want to fill the room (maybe randomly), but efficiently, then this is not the optimum way both because the directivity isn't that way inclined and because it changes with direction.
Headphones (good ones of course) can show you how clean a reflection free environment can be, except that speakers can be so much better .
Old 16th December 2018, 06:52 PM   #112
Bicicletta is offline Bicicletta  Europe
It could be useful play with a simulator.
A driver radiates in the whole space, wavelenghts long compared to the baffle.
It radiates high frequencies in half space. In beetween it's a mess.
Two images: a box 30cm wide, radiates 400 and 4000 Hz
Old 17th December 2018, 02:54 AM   #113
Brett is offline Brett
Brett's Avatar
Some people do, I don't.
I have.
Old 17th December 2018, 03:00 AM   #114
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
I like little cones, but they have to be horn loaded
Don't Procrastinate....Just Do It!
Old 17th December 2018, 05:33 AM   #115
Brett's Avatar
Touche.
Old 17th December 2018, 10:12 AM   #116
Voila
Old 17th December 2018, 10:18 AM   #117
It is possible to create any directivity at any frequency. It isn't always easy.
Before you try you should know what is useful for the room to work with. There are a number of ways to approach it, and there is not one way to illuminate a room precisely. Once you figure out what is and isn't audible, and how far you are prepared to go, and what is mandatory (such as tweeter at ear height), then clear options will follow.
Old 17th December 2018, 10:46 AM   #118
Damn! I'm just working on a simple 2way, with tweeters installed at 2.2 meters.
Old 17th December 2018, 08:54 PM   #119
OK then, going back to your original question.
Can a direct radiatior bring more easily and faster to a random reverberated field?
You want to fill the reverberant space, and probably reduce the early reflections. One thing you can do is sit close enough that you avoid the ceiling reflection. If you place the speakers well apart the opposite wall reflection is longer. The near wall will be stronger.
What you can do is treat the nearby reflections with absorbing panels. Remember that the tweeter goes narrow at the top end and its reflection may suffer.
Old 17th December 2018, 10:57 PM   #120
GM is offline GM  United States
GM's Avatar
Hmm, I take it to mean he wants to 'light up' the room as quickly and as much as possible, which at minimum would be the tiny driver/baffle well away and angled from the sound wall and up or down vertically depending on the room acoustics and/or personal preference to create an concert hall bowl type reverberant sound field.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
The Preference for Direct RadiatorsHide this!Advertise here!
Tube socket preference TUBESMAN Parts 7 11th November 2018 09:19 AM
Reference vs. preference pnix Full Range 41 16th January 2015 02:21 AM
Horns x direct radiators x listening distance angeloitacare Multi-Way 12 9th July 2013 10:16 PM
Power Supply Preference jlind54 Power Supplies 69 9th December 2012 04:35 PM
Listening preference.... Harlan Tubes / Valves 34 5th November 2011 05:58 AM
Copyright ©1999-2019 diyAudio
