Massive SEAS nextel Crescendo tweeter 3 way center channel
Denibeni, I believe inverting polarity would indeed be necessary for LR2 if drivers were time aligned physically. Since they are not, then matching the phase has to compensate for the driver offset. Also with dsp, his connection is rather arbitrary because he is correcting phase and time alignment digitally. We can all learn from each other if we are patient. Beautiful work, I bet they sound awesome. Craig
I have no doubt that it sounds good, and looks good too.
If you can time align with DSP, then it is more true that you can use the drivers with opposite polarity for best result with LR2.
Maybe i am not alone who like to see some measurements, it is always a good thing.
I was probably too critical at the beginning, i am sorry for that. If it sounds good (mainly for the OP), then this is what matters most.
