Yuichi A290 CAD plans
Old 18th July 2019, 04:09 AM   #41
Joseph Crowe is offline Joseph Crowe  Canada
Originally Posted by daemonsgr View Post
if you want to build an 290 (not S, but the question is generic) for a 1.4in driver (like 4594nd) how would you design the end bit (throat etc)? Is it ok?
A smaller throat does present an opportunity to improve the transition between the compression driver’s own exit angle and the 45 degree horizontal throat angle in the A290.
The Radian 850PB for example has a wide 16 degree exit angle, so the transition should be made as smooth as possible. To this end I do offer throat adapters with very complex internal geometry to reduce the effects of the abrupt physical change in the flare geometry in the throat. To machine the adapter requires a two piece assembly so that I can approach it with my CNC machine’s ball nose cutter.
For DIY I can share the design or solid model, just email me at Joseph_crowe(at symbol)Josephcrowe.com
Old 10th August 2019, 12:15 PM   #42
manudrz is offline manudrz  France
Hi guys, so, is anyone sharing his CAD files for it
Old 10th August 2019, 01:03 PM   #43
daemonsgr is offline daemonsgr  United Kingdom
from what I understood there is no freely available CAD.
Ill make one myself. If you end up making one first please let me know
Old 10th August 2019, 03:03 PM   #44
I'm just starting thinking about it, so in 1 or 2 years perhaps
Otherwise, I found a link to an archive on a french forum, thanks to his member for pointing this:
Wood Horn
I didn't know it has been "saved"
Old 10th August 2019, 03:40 PM   #45
Wood Horn
Sorry I might have misread your post. You said about CAD file.
I have the pdf/2d old drawing and the 'web archived' site.
Did you find the CAD file though?
thanks
Old 10th August 2019, 04:05 PM   #46
No, you didn't misread, but anything is good to take. No CAD files sorry...
Old 13th August 2019, 04:12 AM   #47
atilsley is offline atilsley  Australia
My CAD files are made 2D, but the incremental steps for the main curve are 1mm, making the finishing/sanding easier.
Old 13th August 2019, 07:08 AM   #48
Can you share?
Old 13th August 2019, 11:12 PM   #49
mp9 is offline mp9  United States
^ +1 on that request. TY
Old 14th August 2019, 01:21 AM   #50
Can you share?
I can, but it's commercial with small $ attached. Please PM me as such. Kind regards.
Yuichi A290 CAD plansHide this!Advertise here!
77Hz Conical, Yuichi A290, Beyma TP-150h project kodomo Multi-Way 13 11th October 2018 06:40 AM
Yuichi A-290 calculation Help cobrettie Multi-Way 7 25th June 2018 09:00 AM
Request for SEOS-24 and Yuichi A290 comparision silent_riot Multi-Way 54 3rd August 2017 03:36 PM
Yuichi A-290/TAD TH4001 vs Edgarhorn neskor Multi-Way 0 4th December 2011 07:07 PM
TAD or Yuichi Arai cad horn plans? cka3o4nuk Multi-Way 0 14th June 2011 08:57 PM
Copyright ©1999-2019 diyAudio
