Scan speak repair help
Old 24th November 2018, 02:39 PM   #1
200rmsmin is offline 200rmsmin  United States
Default Scan speak repair help
I have 2 scan speak P17WJ-00 6.5 woofers. The rubber surrounds are partially separated from the PP cones. I contacted scan speak to seek advice for an appropriate glue. They use a high tech welding process (corona) during manufacture but suggested super glue (cyano). All of the super glues I saw warn that they should not be used on polypropylene. Madisound recommends Mcnett seal cement. Anyone have any experience with this situation?
Old 24th November 2018, 02:55 PM   #2
Lojzek is online now Lojzek  Croatia
Lojzek's Avatar
I have achieved very good results with neoprene glue while repairing the old foam surround attached to a poly cone.
Old 24th November 2018, 04:03 PM   #3
Gregje is offline Gregje  United Kingdom
I have refoamed Vifa C17 and Proac 3.5 ScanSpeaks using the glue supplied with the foam surrounds by www dot audiofriends dot nl. I am pretty sure you can source something like this more locally. It looks like a PVA glue but dries faster, yet not too fast. It allows you to make adjustments. It is white but dries transparent.
Scan speak repair helpHide this!Advertise here!
Scan-Speak 8545 lead-wire repair? wreckingball Multi-Way 9 5th September 2016 09:50 AM
FS: Scan-Speak Illuminator d3004/60200 Tweeters, Scan-Speak Discovery 10f Midrange bikinpunk Swap Meet 1 27th September 2010 04:13 PM
Scan Speak 23W sub Pan Subwoofers 15 26th December 2007 07:13 PM
Scan Speak 15M Jed Multi-Way 27 23rd March 2007 08:45 AM
scan-speak 3-way dre73 Multi-Way 1 18th November 2005 02:05 AM
Copyright ©1999-2019 diyAudio
