First pair of DIY speakers. Advice please?
Old 7th November 2018, 02:30 AM   #1
Southwood is offline Southwood  United States
Default First pair of DIY speakers. Advice please?
Hello Folks,
I am looking to build some speakers for this integrated amplifier:
Valve Audio Predator integrated amplifier – Reviews | TONEAudio MAGAZINE
I'll run a PS audio Nuwave DAC into the amp.
The amp appealed to me because it's a Valve/Transistor hybrid. It happens to be very powerful which is not why I bought it.
-room is medium-sized(speakers will be 3 ft from back wall, due to immovable cupboards so ports matter: low, rear port will fire into the cupboards)
-dynamics, neutrality and speed are more important to me than bass
-I don't listen to rock and I don't listen to particularly loud music
-I have a buddy who is an excellent carpenter and he'll help me build the cabs
I guess my questions are:
-which kits in the $500 - $700 range represent good value?
-which of those kits can be modified in time?
-what spec. should the kit to have to integrate with the amp?
I have a very neat tri-aktiv Linn system right now, and I listen very carefully to a range of audiophile setups so I am calibrated to a certain degree.
Thanks in anticipation.
David
Old 7th November 2018, 04:45 AM   #2
PKI is offline PKI  United States
PKI's Avatar
I strongly suggest you to make a set of Kairos or Kalasan. There are speakers that do somethings better, it is always a compromise, you know... but those satori drivers just sound really good together. With time you will be able to change the tweeters to Be if you like and add bass modules to them.
Old 7th November 2018, 06:46 PM   #3
Ita0101 is offline Ita0101  Israel
+ Kairos.
I'm building the Adelphos, which is the same as the Kairos only with flat baffle.
Right now when the speakers with baffle only without the full cabinet, they sound awesome. detailed and clean sound. Very natural. They reminds me Sonus Faber Cremona.
I have vifa XT + HDS 2 way speakers, made by french manufacturer Elipson. The Satori sounds very similar - only better in every aspect. the tune and color of the sound is very similar.
PKI - Is there a simple way to upgrade to Be?
Old 7th November 2018, 10:39 PM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Originally Posted by Southwood View Post
Hello Folks,
David
Hi David,
I would not call the 500-700 dollar range exactly good value, rather a more expensive parts kit selection in accordance with current fashion. I suspect that pretty much all the kits available at the usual stores we know here, have already passed the initial test of worthiness at some diy audio show or otherwise the stores would not have carried these at all. A kit of good value in my opinion is any kit like Zaph's SR71 for instance.
A kit can be modified at any point, that is entirely up to one's own know-how. Whether a kit designer has foreseen a future mod of some sort is best to ask directly.
No particular spec is necessary to meet the criteria of driving it with the amp of your choosing. You know that there is no warranty for overdriving voice coils.
I would recommend a Vincent-Tac company as a great manufacturer of extremely good value for the buck hybrid amps.
"Immer wenn du denkst es geht nicht mehr, kommt irgendwo ein Lichtlein her."
Old 8th November 2018, 04:11 AM   #5
Tweet is offline Tweet  Australia
Hi Southwood,
You may like some of these kits from SB Acoustics or get the parts together over time where they can be reused for a more advanced system.
SB Acoustics :: SB Acoustics Kits
C.M
Old 8th November 2018, 05:18 AM   #6
PKI's Avatar
Yep
Old 8th November 2018, 10:45 AM   #7
Originally Posted by PKI View Post
Yep
Just ro replace?
Old 8th November 2018, 11:06 AM   #8
burgunder is offline burgunder  Denmark
This kit from Troels Gravesen is good value I think SBAcoustics-61-NAC
First pair of DIY speakers. Advice please?Hide this!Advertise here!
Advice For Pair Of Small Double Duty Subs weltersys Subwoofers 46 6th August 2016 06:43 PM
Advice on internal wiring upgrade for a pair of B&W 800D's soundengine355 Multi-Way 83 4th May 2015 01:24 PM
Advice sought. LF driver to pair with 808-8a's? gmoore3181 Multi-Way 4 11th August 2014 01:41 AM
How cheap can you get? ~$60 assembled pair w/ bamboo enclosures - offer advice. -=Germania=- Full Range 79 8th January 2009 05:58 AM
Good pair of speakers for <$200/pair? asauer Multi-Way 73 19th May 2004 11:47 AM
Copyright ©1999-2019 diyAudio
