Greetings all,
I do not seem to be able to find dimensions for the JBL 2384. Does anyone know a reference that would have them? Alternatively, could someone measure the horn?
I am interested in both the outside dimensions, and the (inside) dimensions, i.e., the dimensions of the mouth without the mounting flanges.
Thank you,
M
Thank you,
M
Hi Norman,
thank you very much for your answer.
Yes, I want the the mouth size before it bends flat parallel with the front baffle.
On a different, but related note, I contemplate to make a spacer to use them with 1.4 inch Altec 288. If that does not work, I will consider some 1.5 drivers. What do you use?
Kindest regards,
M
Kindest regards,
M
jbl 2435hpl (beryllium).
I have an ev dh7 (need one) on an ev hr90 horn, I used that before upgrading to the jbl / jbl.
3rd post down
Hifi sound quality with PA SPL - Speakerplans.com Forums - Page 6
but I think that is a 1.4".
wow, a 288, much sought after.
3rd post down
Hi Norman,
thank you for the reply. I found your listing for the JBL driver, but the listing is rather confusing; on 10/62018 it says "No longer for sale by me", but then there is bump on 10/08/2018, and you current thread says "2435hpl i have for sale".
Is it still for sale? One or two?
Kindest regards,
M
Kindest regards,
M
- JBL 2384 horn dimensions?
