Horn Sensitivity calculation
Old 25th October 2018, 11:07 PM   #1
Loudbass is offline Loudbass
Default Horn Sensitivity calculation
If we take a look at a driver datasheet here: Specification
We can see that it specifies a 114dB sensitivity for a 9075 CD horn. Does this mean that we can get up to 130dB of sensitivity in a narrow horn, like the 13 maltese horn?
The rule of thumb I'm using here is that for every halving of the horn radiation angle, we get a 3dB boost. Because the 13 horn has almost 1/40 the angle, it gets 16dB louder, thus the 130dB sensitivity.
Something is not right here! AFAIK no one has reached this SPL at 1 watt!
Old 26th October 2018, 04:19 AM   #2
GM is offline GM  United States
GM's Avatar
Well, a PWT is 0 deg and the driver is 118 dB/mW, so at 1W it's going to be 1000 times more = 118+30 = 148 dB in theory, so 13 deg will be somewhat less as you noted.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th October 2018, 06:03 AM   #3
I just can't believe the number!
Old 26th October 2018, 07:28 AM   #4
TBTL is offline TBTL  Germany
A 13 degree horn will be huge. If it must hold its pattern down to 1 kHz, it will have a mouth diameter of 2 meters. And then the length..
Old 26th October 2018, 08:27 AM   #5
Nooo... Weltersys' Maltese horn has good specs at a relatively small footprint ( pics below). Also, It's easy to build and doesn't take too much time and stuff... I would love to build something that produces deafening sound levels with just a few milliwatts...
Old 26th October 2018, 09:11 AM   #6
as_audio is offline as_audio
GM
This is a typo, it must be 118dB/W.
Old 26th October 2018, 09:19 AM   #7
And another thing- I looked through other BMS products and noticed they have tested their bigger drivers (4599, as an example) using much more narrower 2040 horns...
If the 4540 could approach 130dB/w.m so easy why BMS didn't publish the amazing numbers as an advertisement?
No I don't think so. This driver gives 114dB through a 90deg horn, 118dB/W is too low for its PWT, IMHO.
Old 26th October 2018, 10:39 AM   #8
Compare to the other BMS spec sheets.
Old 26th October 2018, 12:23 PM   #9
The horn mouths will only maintain the 13 degree pattern above 7 kHz, at lower frequencies the dispersion will widen.
The dispersion angle can be approximated by:
angle [deg] = 25400 [m*Hz*deg] / (horn width [m] * frequency [Hz])
Old 26th October 2018, 10:26 PM   #10
Interesting equation! It seems like the iron law for horn directivity but where does the constant number come from? And what about horn length and flare rate? Should I just go simple and assume the radiation angle is the same as horn angle?
And what is this angle exactly? Is it the -3dB angle or the -6dB or... I'm curious because at 2KHz the angle is still under 40 which is pretty impressive.
Also, this reminded me of hailing devices. I now looked among some of them and they were claiming strange specs like 30 directivity at 1KHz with a tiny hand held device. What is going on with them? That is soo far from what this formula suggests. The horn size of theirs sets them off orders of magnitude and exponential flare rates and EQ is of little help at this situation.
HS-10 (Bullhorn / Megaphone Replacement) | HyperSpike(R)
Horn Sensitivity calculationHide this!Advertise here!
Conical horn calculation Tyimo Full Range 13 20th April 2014 09:43 PM
Horn sensitivity question kctess5 Full Range 25 21st January 2013 04:54 PM
need help with tapped horn calculation... morpheus82 Subwoofers 32 19th May 2011 11:38 PM
Tweeter sensitivity calculation Tyimo Multi-Way 4 29th January 2008 12:07 PM
LeCleac`h cylindrical horn calculation spacejerk Multi-Way 5 9th November 2004 07:10 PM
Copyright ©1999-2019 diyAudio
