Klangfilm spherical wave horn calculator - from round to elliptical
Old 14th March 2019, 07:39 PM   #91
docali is offline docali  Germany
docali's Avatar
Originally Posted by Patrick Bateman View Post
You can get nice results by using two horn profile, rotating each one by about thirty degrees, then smoothing the results.
You wind up with a profile that's similar to the JBL progressive transition waveguide.
Basically you want the beamwidth to be longer on the diagonal. The net result, based on my measurements and sims, is that the resulting waveguide has *wider* beamwidth. Which is a bit non-intuitive, that narrowing the vertical and horizontal parts of the waveguide actually *widens* the beamwidth.
These strange looking JBL waveguides. We can use a mathematical function that was suggested by Giovanni Domenico Cassini and play around with some parameters then we can get this here:
Old 14th March 2019, 11:32 PM   #92
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by pinkmouse View Post
Yup, it is, but you can set an offset in your slicer for different material presets, (I've done it using Cura and Prusa Slic3r, I know it works in S3D as well, and probably most others). and never have to do a level again. I set it with the pre-print initialization g-code, as a line after the auto level commands.
I use my printers for lots of things, so the purple diy job will stick with 0.4 for now, the JG will get a Volcano and 0.7-0.8 for big/fast stuff, and I'm not sure about the Big IDEX job I'm currently designing.
I'll take a look at my settings, thank you!
Old 14th March 2019, 11:33 PM   #93
Attachment 742828
Attachment 742829
WOULD YOU JUST TAKE MY MONEY ALREADY
Set up a gofundme or something, I need this software
Old 15th March 2019, 07:37 AM   #94
docali's Avatar
Thanky you for the flowers:
But this is currently "only" a theoretical work without practical justification. Pleae be patient.
Old 14th April 2019, 09:37 PM   #95
jzagaja is offline jzagaja  Poland
Time to make spherical flooder :-)
File Type: png 8556B371-178F-469F-9DEE-6FB316877701.png (403.2 KB, 43 views)
Visit us at http://www.diysoundgroup.com
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Klangfilm spherical wave horn calculator - from round to ellipticalHide this!Advertise here!
Klangfilm L307/Siemens LSP15p horn design help SETorbust Full Range 9 29th November 2017 08:52 PM
Wave-front shape and impulse response: spherical, cylindrical, plane-wave keyser Multi-Way 27 18th January 2017 05:32 PM
DIY Klangfilm Eurodyn w. 15"woofer+tractrix horn tralalalala Full Range 6 20th November 2016 11:13 AM
K-horn, Klangfilm kl51 SoundRight Planars & Exotics 0 27th November 2015 06:14 PM
1/4 Wave Flared Vent T-Line/Horn/Bass Reflex Enclosure Calculator heyday Subwoofers 1 14th September 2010 11:53 PM
Copyright ©1999-2019 diyAudio
