"Betriebsleistung"/"operating power":what does it mean?
Old 14th October 2018, 06:30 PM   #11
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Originally Posted by Peters8 View Post
According to the DIN45500 norm, a speaker (to be a real hi-fi stuff) must achieve 96 dB...yes, you're right...I've read that in an old hi-fi magazine.
Thank you for the help!
Probably also the 20-20000 Hz rule had to be fulfilled
Everything under and above heaven is in utter chaos
mare monstrum
Old 15th October 2018, 03:38 AM   #12
Peters8 is offline Peters8  Italy
Hi Tony! what a pleasure to see another italian here!
Where do you live in Italy?I'm from Sicily!
Ciao
Old 15th October 2018, 04:45 AM   #13
Calvin is offline Calvin  Germany
Calvin's Avatar
I assume there´s an misunderstanding regarding the 96dB thing.
There was afair no specification for the efficiency of a speaker.
The 96dB figure related to the minimal maximum SPL the speaker should achieve.
jauu
Calvin
Old 15th October 2018, 06:49 AM   #14
phase_accurate is offline phase_accurate
Fortunatley it didn't. Otherwise veeeeeery few speakers of the 60ies and 70ies would have been able to fulfil the DIN norm for HiFi. Even today not many would pass either BTW.
I think we need to be a little more accurate here. There was the minimum SPL that had to be achieved in order to fulfil the norm as you mentioned. There was no minmal efficienciy value that had to be reached. I guess this is what you meant to say. But as already mentioned decent manufacturers published the "Betriebsleistung" of their speakers which is the power that is needed to reach a certain SPL value which made chosing amplifier/speaker pairings a Little easier.
Charles
"Betriebsleistung"/"operating power":what does it mean?Hide this!Advertise here!
Philips 503 (DC503, "79 DC 503/62") Operating Instructions and Service Manual wanted tiefbassuebertr Car Audio 0 28th August 2018 08:29 AM
"WTB" "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral enantra Swap Meet 3 23rd December 2012 06:36 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 5 13th October 2012 05:18 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 04:33 PM
