Mackie HR824 mk1 internal foam
Old 12th October 2018, 12:45 PM   #1
Ugg10 is offline Ugg10  United Kingdom
Default Mackie HR824 mk1 internal foam
Anyone know what spec the foam is inside the woofer compartment of a Mackie HR824 mk1. All I can find is "adiabatic foam". Need a block approx 9" cube. UK suppliers preferable or just links to similar so I can try and source.
Reason is I bought a "for parts, distorted" one of ebay for a little more than pocket money. When it arrived only the tweeter was working, checked the amp out, all OK, did the battery test and woofer was dead. So, opened up the front and found that the foam was missing and the woofer not connected. Connected it up and all was fine but sounds a bit boomy without the foam. So, good result but need the foam to get it back to square one.
Mackie HR824 mk1 internal foamHide this!Advertise here!
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
Looking for the best Foam for internal damping of a bass cabinet. Any recommendation? murphythecat8 Multi-Way 40 23rd February 2013 10:39 AM
Mackie hr824 woofer mikeydread Parts 3 24th December 2009 05:05 PM
Foam, thicker foam or Open Cell qguy Subwoofers 4 11th March 2007 08:06 PM
Mackie VLZ Pro mic pre? mhelin Instruments and Amps 3 16th July 2004 12:45 AM
Copyright ©1999-2019 diyAudio
