calculations for spherical enclosure.
Old 6th October 2018, 11:24 PM   #21
Galu is offline Galu  Scotland
Call me mathematically challenged, but I don't understand that lens volume calculator!
Old 6th October 2018, 11:34 PM   #22
This one's better - click on Sphere Radius 'r' & Chord 'AB'
Spherical Cap Calculator
Old 7th October 2018, 01:41 AM   #23
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Your link is indeed easier to see and use, but in case anyone is interested in alternative shapes...
That lens calculator describes a biconvex lens with a cylindrical middle section between the two convex surfaces.
r1 - describes the radius of curvature for the (spherical) convex surface on the left
r2 - describes the radius of curvature for the (spherical) convex surface on the right
rc - describes the radius of the cylinder that intersects the two convex surfaces
hc - describes the length of the cylinder between the two convex surfaces
In the case of the OP, we want the volume under one spherical convex surface cut off by a plane.
The plane intersects as a circle with whatever radius the OP wants as his opening.
As an example, let's use a 14" diameter sphere with an 8" speaker. Ignore baffle size, kerf, etc for the sake of demonstration and assume we want a hole with an 8" diameter.
So we want the intersection in our case to be flat circle, a cylinder with a height of 0 and diameter of the speaker. This gives us:
hc = 0, and
rc = 4
Using the left convex side as our spherical cap to be removed, which is being cut off the 14" sphere, giving us:
r1 = 7
We want the right surface to be flat, not convex. So the radius of the right side should be infinity, or high enough to be of little consequence. Let's use:
r2 = 10000
Inserting these values into Richidoo's link gives us 32.609 for the volume of the spherical cap to be removed from the OP's sphere.
In Galu's link, using r=7 and chord = 8 finds a spherical cap volume of 32.589 that's pretty good agreement.
The lens calculator does bring up the thought of alternative enclosure shapes employing spherical baffles.
Tim
Old 7th October 2018, 04:18 AM   #24
A 'pretty good' agreement? To three significant figures the two calculated volumes are identical (32.6)!
Old 7th October 2018, 12:15 PM   #25
P.S. No offence intended to Richidoo and tsmith1315!
While the Spherical Cap Calculator better fits the needs of the OP, I take the point that the Lens Calculator is more comprehensive.
Old 7th October 2018, 03:12 PM   #26
Aucosticraft is offline Aucosticraft  India
Originally Posted by Richidoo View Post
The formula you want is simple arithmetic, but it requires that you inquire with the driver manufacturer to find out the driver displacement (volume of portion of the driver that is behind the driver mounting flange.) Mfgs know this but it is often not published. You could also make a close enough estimate yourself. Call this displacement volume "D."
Then you need to determine the volume between the driver mounting plane cut into the sphere and the concave surface of the portion of the sphere that is removed. This is a lens shaped volume, so you can determine that volume using this online calculator. Be sure to use the "thru hole" dimension for the diameter of this volume, not the overall flange rabbet diameter that is cut into the sphere walls. Call this lens volume "L"
If you make the speaker ported, then also subtract the volume of the port from the box volume - the outer port tube dimensions and the space inside it. Call this port volume "P"
Volume of a sphere is 4/3*pi*r^3. call this "S"
Your formula for the net volume remaining inside the sphere when you cut the driver hole and install the driver (enclosure working volume) is:
V = S - (L + D + P)
There are some sources of acrylic and polystyrene foam spheres of various sizes online.
When choosing the diameter of your sphere, also consider how it will affect the baffle step for your filter and EQ designs.
Spheres have a lot of volume inside that will usually exceed what you need for good bass alignment. So you can build a more traditional box shape inside the sphere to minimize internal sound reflections acting on the driver. Non parallel walls, etc. You can make these from thin plywood, then just glue them to the inside of the sphere then fill the void with expanding urethane foam through some holes in the plywood. Make a lot of holes so the foam can expand easily, then cut it flat after foam hardens. Or you can just spray the foam in blobs, measure the volume with sand and cut away to achieve the volume you want. Or use liquid concrete to make the walls, etc. If you're doing a sealed speaker the volume is not too critical, but a ported speaker box volume (Vb) is critical.
Yes, My primary intention for using spherical enclosure is to get smooth diffraction curve. There is nothing we can do to avoid it completely. And it holds true even for different axis response. This makes easy to correct the diffraction electronically or electronically.
This design is going to be a sealed enclosure. And can work till 80Hz down. They can be used as Satellite speakers with subwoofer or as a standalone bookshelf. (Although not going down to 30Hz.)
The link you shared "True Audio TechTopics: Diffraction Loss" was referred. But i had found more detailed measurement document where they provided detail plot. Unfortunately I am not able to find it again. My bad , Should have bookmarked it.
I soon would need something that would calculate (simulate) diffraction for sphere. If you know any please help.
There is always a first time....
Old 7th October 2018, 03:14 PM   #27
Originally Posted by scottjoplin View Post
Don't forget the volume the driver occupies
Yes Driver displacement should be to Vb during calculations.
Old 7th October 2018, 03:16 PM   #28
I understand , everyone here has put best efforts to get the solution.
Old 7th October 2018, 07:54 PM   #29
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
I've been able to achieve VERY nice polars by using elliptical enclosures:
The Advantages of a Diffractionless Enclosure
They sound really great too. Highly recommended, and easy to make.
Old 7th October 2018, 11:32 PM   #30
hollowboy is offline hollowboy  Australia
If that is the primary intention, then a bigger sphere = better.
If you want go for the biggest and/or smoothest practical enclosure for optimal diffraction, there's not much point in calculating the volume to 3 decimal places.
This edit signature thingy is seriously hard to find
calculations for spherical enclosure.Hide this!Advertise here!
Spherical Enclosure Considerations romanoaf Multi-Way 13 11th March 2017 11:41 AM
Which driver in 4L spherical enclosure? Forane12 Full Range 6 10th December 2015 06:33 PM
ported spherical acrylic speaker enclosure neebster Full Range 23 1st July 2014 12:07 AM
spherical enclosure MrSensitive Subwoofers 94 6th March 2006 08:06 AM
Materials For Spherical Enclosure Ignite Multi-Way 15 12th December 2001 09:15 AM
