Transmission line Omni speakers? Duevel Planets clone with transmission line?
Old 29th January 2019, 10:06 AM   #51
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Hi. Interesting. I tend to agree, even a straight sided cone would be better than a sphere. The more directional high frequencies, will tend to be reflected back down, others will curve around a sphere and be reflected off the ceiling. You have to ask yourself, how many omnidirectional speakers out there use a sphere as the reflector?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 29th January 2019, 10:27 AM   #52
DeeLuxx is offline DeeLuxx  New Zealand
Yea i did a few measurements where the mic was about 45 degrees to the horn and i agree, it seems as though the high frequencies appear to curve around the sphere.
Will be interesting to see how the woofer/sphere combo behaves, but definitely seems less than ideal for the horn/CD.
The Duevel Enterprise speakers look like they have a more suitable reflector for the HF
Old 29th January 2019, 01:41 PM   #53
freddi is offline freddi  United States
freddi's Avatar
1950's GA Briggs design for wideband 8"
https://www.audioxpress.com/assets/u...drainpipe8.pdf
Old 30th January 2019, 02:31 AM   #54
DonVK is offline DonVK  Canada
DonVK's Avatar
Maybe a different planet is required . I was thinking about how you could try a few ideas with those spheres. All of them ruined the aesthetics of course. The horn is 25cm ID, the sphere is 14cm OD, the disc is 23cm, and the cone is 5cm ODx3cm. Compare them to just using sphere in post #21. The field at the top of the sphere is a little jagged from simulation resolution used.
Old 30th January 2019, 03:23 PM   #55
DonVK's Avatar
..and the cone.
Old 30th January 2019, 03:30 PM   #56
Gosh, that looks awful! What if it was twice the size, at least?
Old 30th January 2019, 04:15 PM   #57
DonVK's Avatar
It does. The problem is that it's hard to change direction unless you can provide both an inner and outer surface to support that direction change.
The sound will bounce off the walls as you can light up the room and it can even out by diffusion. You also need enough room for spacing and delays.
Old 12th February 2019, 01:32 AM   #58
Hi, sorry been away for a while and hadn't seen the posts.
I like the ring/sphere idea (saturn?), i'll give that a go.
Our cnc is down at the moment so might put a hold on things, but will see what i can do by hand.
Also think it might be easier just to 3D print a reflector instead.
Transmission line Omni speakers? Duevel Planets clone with transmission line?Hide this!Advertise here!
WTB - Transmission Line Speakers Triodeasaurus Swap Meet 1 16th July 2014 07:41 AM
Transmission Line speakers steevo Planars & Exotics 2 26th March 2008 08:33 PM
Transmission Line speakers jjbmon Multi-Way 5 25th February 2008 03:03 AM
Transmission Line Speakers GeeVee Multi-Way 4 26th July 2007 01:24 PM
Transmission line speakers, sub, amp bbaker6212 Swap Meet 0 20th December 2002 08:29 PM
Copyright ©1999-2019 diyAudio
