Open Source "Tower XL"
Old 26th August 2019, 05:42 PM   #881
Aatto is offline Aatto  United States
Aatto's Avatar
Default Quick Update
hello everyone.
Received the boards, 3/4" (19mm) 4'x8' (1.2m x 2.4m) MDF,
So yup, it's officialy started, I have finalized the drawings and will post a detailed sketch later, one thing I realized tho is that each cabinet will weight around 100-120lb (about 60kg) without the drivers , So i m going to add some kind of dolly or add two casters to the back side of each cabinet so I can just tilt it toward the back and move it around if I need to.
I will start working on this but I have my schedule full until after October, so don't expect a lot of progress till then
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 26th August 2019, 07:11 PM   #882
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Great! I am sure the boards take up a lot of space and stand in your way. You need to change this. Cut them, glue them, make something nice! You will enjoy it!
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 26th August 2019, 09:06 PM   #883
Aatto's Avatar
hmmm, I wonder
I probably need to get a track saw for these, the boards are way to heavy and big to cut on the table saw by myself and I also don't trust myself with a circular saw to get straight cuts, hmm, will see...
Old 9th September 2019, 12:11 AM   #884
LineSource is offline LineSource  United States
LineSource's Avatar
Can you "phone a friend" to assure safe cuts of these large MDF sheets?
If you can post the final drawings you may get support from another builder with a larger wood shop and more experience to discuss safe working methods.
Old 9th September 2019, 12:41 AM   #885
vlv81 is offline vlv81  New Zealand
Could you clamp or otherwise affix a straight edged piece of timber and run the circular saw along that. Possibly you could mark out the actual wanted pieces and then cut areas not needed and tidy up the more manageable pieces on your table saw? A couple of ideas that may be of use or not
Old 11th September 2019, 06:24 PM   #886
mbrennwa's Avatar
Or use a jigsaw? This is just a prototype, and it does not have to look nice.
Old 30th September 2019, 08:17 PM   #887
Aatto's Avatar
Default Some updates
Sorry for my long absents, I m getting married in a few weeks and barely have time for anything else.
I had a little progress tho, I got a track saw but it feels cheap and flimsy, so to make it more accurate and avoide more cutting than necessary I made a little jig around it.
I just went with it without any planning but it turned out good, I secured the tracks tightly on a large board, glued some blacks around it to stop it from moving around and loosing its accuracy, for the next step I m gonna cut the board off with the saw on the track, this way the cut would be my guid to make the future cuts and it will be accurate (the same idea from a table saw sled jig but here the jig is stationary and the saw will move across). lesson learned tho, next time I wouldn't buy a track saw, a nice jig with a cheap circular saw would do the job just as good.
I don't think I will have much progress for the next month or so, so please be patient.
Old 30th September 2019, 08:32 PM   #888
Aatto's Avatar
Sorry for late replay
I wanted to have a permenant solution for future projects and I found a good deal on the track saw so I just went for it, hopefully this jig will serve me for a while, and I can cut long crosscuts by my self, next is to make the jig vertical kinda like what they have at home depot, shouldn't be that hard and there are a bunch of youtube videos about it.
also I m working on the drawings as well, attached is the latest one.
yes that would be one solution but I wanted to avoid more cuts just to clean up the first cut and wasting more material than I should, if this jig turn out good and accurate enough, it may help others as well to build one
you know it has to be nice
I figured the cabinet would stay the same size, maybe some minor changes, and I will make the front baffle exchangable so if it turn out good, I can use the same cabinet and only build one more.
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 04:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 06:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 05:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 09:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 07:17 AM
Copyright ©1999-2019 diyAudio
