Open Source "Tower XL"
Old 15th December 2018, 03:05 PM   #781
LORDSANSUI is offline LORDSANSUI  Brazil
hi pcgab,
last questions about woodwork:
how many watts has your router?
the circle guide is an accessory sold separately? how much it cost?
Old 15th December 2018, 03:30 PM   #782
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by pcgab View Post
I can make a pass with the router, jump a few spots down the circle guide, route, repeat, until I get to the final mark.
Why don't you use a larger router bit and do it in one pass? Do the small bits have any advantage over the large ones?
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 15th December 2018, 04:09 PM   #783
ILikeFoodz is offline ILikeFoodz  United States
Originally Posted by LORDSANSUI View Post
hi pcgab,
The router is 1678 watts / 2.25 hp. It's the Bosch 1617 EVSPK I believe. Personally I have the MRC23EVSK, which is also an excellent router.
The circle jig looks like a Jasper circle jig, works very well. Not 100% sure which model pcgab has
mbrennwa, generally I have found that larger shank router bits will result in a better cut, but good results can be achieved with smaller ones as well as we can see from pcgab's excellent work here. The most important thing equipment-wise is to buy a high quality bit in my opinion, and to make sure you're using it properly (correct speed on your router, which I determine with scrap and trial and error). Personally, all my bits are Whiteside and CMT. I prefer the Whiteside ones slightly because I find I get somewhat better/cleaner cuts with them.
Old 15th December 2018, 04:57 PM   #784
pcgab is offline pcgab  United States
The bit I used to cut those is Whiteside, they make great bits.
Pretty sure that's the model router I have, and it is a Jasper circle jig. 'Jasper 200J Model 200 Circle Cutting Jig for Plunge Router'
I used that bit, a 1/4" cutting diameter bit because it was recently sharpened and it is a spiral down cut, which tends to leave the top face a bit cleaner. When I'm cutting work material that's clamped to a sacrificial top on my bench, I prefer the spiral down cut bit. This generally allows the cuts to be executed so that both end up with clean edges.
Gable
Old 15th December 2018, 05:03 PM   #785
They don't have any real advantage in this use case. It was simply what I had available that was sharpest. For a small recess like this, 16-18mm IIRC, it only takes a minute or so to make multiple passes, so it's not terribly inconvenient.
Gable
Old 17th December 2018, 03:09 PM   #786
Aatto is offline Aatto  United States
Aatto's Avatar
I wrapped up the insert for the TD8, got it flush like I wanted.
The mounting ring has a slight flare that makes the transition from cone to baffle even more smooth. Very well thought out driver.
Yes, my machinist square is dirty, I could sand it clean, but there's more important things in life..... single malt comes to mind.
Gable, That looks awesome
Cheers.
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 17th December 2018, 03:19 PM   #787
Aatto's Avatar
I recieved the other HF107 over the weekend, it has been shipped in different packages but the guys at speakerdirect were very helpful.
HF107 looks very well built as you would expect from Faital, it is a big CD and has some weight to it, I dont have my DATS with me at the moment, but we will do some measurements soon.
what was more impressive was build quiality of STH100, solid aluminum piece (casted of course) looks heavy duty, I will post some pics
Old 18th December 2018, 02:31 PM   #788
Aatto's Avatar
pics
Old 19th December 2018, 07:15 AM   #789
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Beautiful!
Things are starting to happen, work in progress: https://kaffimann.com
Old 25th December 2018, 02:41 AM   #790
Aatto's Avatar
Merry Christmas and happy holidays
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 05:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 07:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 06:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 10:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 08:17 AM
Copyright ©1999-2019 diyAudio
