Open Source "Tower XL"
Old 25th September 2018, 03:46 PM   #41
Aatto is offline Aatto  United States
Aatto's Avatar
Originally Posted by Paul Vancluysen View Post
IMO the ATC SCM150 cabinet concept, apart from the midrange dimension at this time, is the most interesting for this project to get the targets.
like this :
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 25th September 2018, 04:17 PM   #42
Paul Vancluysen is offline Paul Vancluysen  Belgium
AE TD6M as midrange maybe ?
With a 15 inch woofer the X-over crossover frequency with the midrange cannot be too high; 400 Hz max, dependent on the woofer characteristics in the mid frequency region.
So a 3 inch midrange combination will become at the limit.
ATC crosses at 380 Hz with their 3 inch midrange. That woofer has a Sd = 774 cm2 (they specify a diameter of 314 mm). That is already a little less than the mean 15 inch driver.
We have to find a 15 inch woofer with a not too high Le value, that it can operate up to a few hundred Hz.
Old 25th September 2018, 04:17 PM   #43
ILikeFoodz is offline ILikeFoodz  United States
Originally Posted by Aatto View Post
4- 2x 8 or 10" inch woofers per cabinet (4 ohms in series ).
Pros: ?
Cons: ?
Could achieve 91dB half space with 1-2 10" drivers.
Seas CA26RE4X one of these has 91 dB efficiency, should be able to get down to F3 of 36 Hz
Satori WO24P-4 two of these would work for 91dB, but expensive.
Old 25th September 2018, 05:03 PM   #44
Zonneschimmel is offline Zonneschimmel  Belgium
I wouldn't call anything with a driver larger then a 10" on the front a "tower".
I'm using the WO24p-4 at the moment (1 per side) together with the 5" satori and the satori Neo tweeter. It's a wonderful driver.
I'm also not the intended audience for this project ;-)
Old 25th September 2018, 05:45 PM   #45
That is my thought as well. I could maybe see stretching it to 12 inches... maybe. But 15 no longer qualifies as a tower in my book. I suppose we could always side mount a larger driver or two though.
Old 25th September 2018, 06:13 PM   #46
Aatto's Avatar
With a 15 inch woofer the X-over crossover frequency with the midrange cannot be too high; 400 Hz max, dependent on the woofer characteristics in the mid frequency region. So a 3 inch midrange combination will become at the limit.
+1 for AE TD6M and also I like lower XO point for woofer/mid anyways. the closest we got was the Eminence Kappa 15FLA. we do not have much options for woofer. they are just simply not many single driver out there w specs we need, so maybe we may have to look at this from another perspective, instead of looking for a driver to match our needs maybe we can find a way to get close to the goal with the drivers we have available. anyhow another driver would be FaitalPro 15PR400. needs quite large cabinet tho (~200 liters).
Old 25th September 2018, 06:19 PM   #47
Aatto's Avatar
you ll need a woofer with sensitivity close to 100 (98-99db) do be able to achieve close to 92db in over all sensitivity after baffle step and all that with a single 91db driver you will end up with close to about 82-83db.
But have to keep in mind that this is not a regular home hifi WAF friendly tower. a tower with this specs will be gigantic, it is just physics.
Old 25th September 2018, 07:42 PM   #48
Drummer2005 is offline Drummer2005  United States
This will be the WTF tower! The Wife Tingle Factor tower!
�� Glenn.
Old 25th September 2018, 08:21 PM   #49
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
Still here! Just have a lot on my plate right now...
What about using two Faital 12FH500? They can be had in 16ohm impedance, so may be possible to use in the same chamber because of parallel connection, and they seem well suited for this application?
Edit:
WTF....? Won't Tinkerbell Ffffffffffff.... forget? Or insert other suitable f-word.
Things are starting to happen, work in progress: https://kaffimann.com
Old 25th September 2018, 09:50 PM   #50
LORDSANSUI is offline LORDSANSUI  Brazil
Hi Aatto,
Probably, one of the two drivers option below will achieve the targets for the LF driver, but I think they are available just here in Brazil, the costs wouldn't be a problem with the current ratio (4,20 R$/U$), but I don't know if this constrain is too much for a world wide project.
Snake HPX2150 (Price = ~U$180 )
Sensitivity: 99dB SPL
Fs: 41,00 Hz
Re: 4,7 ohms
Qms: 9,627
Qes: 0,245
Qts: 0,239
Vas: 150,8 L
Sd: 0,088 m
Xmax: 8,5 mm
Le: 1,08 mH
Bl: 20,157 T/m
No: 4,4%
Mms: 105,0 g
Pe: 800 W
Snake ESX155 (Price = ~U$160 )
Sensitivity: 97dB SPL
Fs: 35,00 Hz
Re: 5,0 ohms
Qms: 7,123
Qes: 0,362
Qts: 0,345
Vas: 193,0 L
Sd: 0,088 m
Xmax: 9,5 mm
Le: 0,92 mH
Bl: 18,5 T/m
No: 2,6%
Mms: 107,0 g
Pe: 600 W
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 05:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 07:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 06:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 10:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 08:17 AM
Copyright ©1999-2019 diyAudio
