Open Source "Tower XL"
Old Today, 01:21 PM   #281
Aatto is offline Aatto  United States
Aatto's Avatar
Originally Posted by Paul Vancluysen View Post
Some thought:
Choosing the TD8M midrange, what will be the alternative 8 inch midrange choice? IMO, we have to try to make the same driver configuration for the two options if possible. Otherwise we will make two different speakers in some way.
Some AE driver dimensions can be found here, Index of /pdfs
as of now AE website has 10x TD8M ready to ship in stock. we will see how my experience goes w AE.
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old Today, 01:36 PM   #282
ILikeFoodz is offline ILikeFoodz  United States
Originally Posted by Brett View Post
claiming it is too expensive seems a tad odd.
That was my thought as well when I suggested the Satori TW29BN-B-8 before Aatto said it was too expensive.
I believe we've allocated a somewhat large proportion of the target driver price to the woofer and midrange, which is why we are trying to keep the tweeter price in check.
Old Today, 01:41 PM   #283
KaffiMann is offline KaffiMann  Norway
KaffiMann's Avatar
Location: Grua, ten minute walk from 60.258792, 10.664731
Yes Paul, the Faital drivers exhibit some resonant behaviour around ca 20hz, this is most likely because of the parameters and the loading is below fs, it is not a problem for me at all when this behaviour is pushed so low in the spectrum, because I can barely hear 20hz at all, let alone if there is an issue with delay or not.
20hz wavelength is about 17 meters or so, and ~30ms delay is less than one wavelength (ca 50ms?) at 20hz. Not trying to bagatellize the issue, but this is exactly the reason I wanted to push resonant behaviour below 30hz, because it will most likely be inaudible. It is also below tuning frequency, I seriously doubt you can perceive it in real life.
The AE TD15X has low group delay because it can not work efficiently in the box and struggles against the design. Personally I blame the low mechanical resistance, but all the parameters work together. The mechanical resistance is part of why you get such low fs, but it demands a much bigger box to be effective. The AE TD15M might be a better choice for this, as I can not understand who will feed this speaker with several hundred watts of power, there should be no need for the high xmax the TD15X provides, and the high xmax value is also wasted, because the box is not optimal for the TD15X.
Edit:
Shortening the port to 33cm works out nicely for the TD15X, but then it goes flat to 40hz and there's no sound under 30hz probably.
FC152
Old Today, 03:28 PM   #284
KaffiMann's Avatar
I meant to say High mechanical resistance.
FC152
Old Today, 03:59 PM   #285
Paul Vancluysen is offline Paul Vancluysen  Belgium
Kaffimann,
I can follow your way of thinking, you like to make a low loss tuning at low frequency. You have a point that the Rms of the TD15X is higher, almost a factor 2.
Do you have experience with the sound of such system, I mean the one like with the Faital?
Have you checked if the F6 and F10 of your and my simulations are about the same? Just to evaluate my Leap BR simulation. It is rather difficult to have a good view on the cabinet and port loss settings in Leap.
Old Today, 05:08 PM   #286
Aatto's Avatar
how about increasing the volume to 170?
Old Today, 07:01 PM   #287
KaffiMann's Avatar
Do you have experience with the sound of such system, I mean the one like with the Faital?...
This here is what I am listening to every single day. Not quite as good as the faital, but comparable.
This is what it measures like using only 5 bands of EQ and no xo, both left and right channels in-room.
THD + N is measured at 1.5%/ca 13.5hz, which is the highest number before the spl rolls off.
You can have a look in my dusty thread.
FC152
Old Today, 07:45 PM   #288
EuroChamp is online now EuroChamp
Hi all,
this thread is very interesting for me - thank you all for your time and effort.
I am in a very similar situation: I want to build a 3-way with 15"/8"/tweeter. It should have 8 Ohm minimum and excellent sensivity - for my tube amp. SQ is my primary concern. The design is almost complete (in my brain). But the bass chassis is not finally selected.
The vented woofer should get approx. 120l (more is possible but not welcome).
I have to agree, the Faital PRO 15FH500-8 is one of the most interesting. And I want to bring the 18-Sound 15LW1500 into play, it calculates almost identical. And the Faital Pro 15PR400.
All three do fit in your project.
There are some good woofers out there, but eighter they need a very large cabinet, or sensivity is too low, or they do not play deep enough - you certainly know that.
reg.,
Bernhard
Old Today, 08:04 PM   #289
Nice! Almost the same BR system as the one we have in mind now.
Did you try also a higher tuning frequency with that speaker to compare with, more B4?
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 04:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 06:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 05:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 09:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 07:17 AM
