Open Source "Tower XL"
Old 3rd October 2018, 10:09 PM   #121
Brett is offline Brett
Brett's Avatar
Originally Posted by Aatto View Post
yes technically we can go active and achieve 100db from a 90db driver
I read this comment as you talking about efficiency / sensitivity, and if correct, no you can't.
Old 3rd October 2018, 10:24 PM   #122
Aatto is offline Aatto  United States
Aatto's Avatar
no not the efficiency/sensitivity of driver or a passive system, overall SPL in active system ( should have added that to avoid misunderstanding ). I might be wrong but back in my studio monitor days I read that they simply feed more power to drivers (in active systems) to have more max SPL, so you have a very high 110db SPL in a very small package that still goes down to 35-40Hz, I know this ahs nothing to do with this thread but so was my point.
one question tho, I did ask this before and it is off topic but how did Zaph got 92db sensitivity from a 90db woofer in SB12.3 ?
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 3rd October 2018, 10:51 PM   #123
montana1 is offline montana1  United States
montana1's Avatar
Hi Aatto,
If you scroll down to the the very bottom of the SB 12.3 page you will find that Zaph gives the answer to your question. It is the first question addressed under the FAQ heading.
Best,
Rich
Old 3rd October 2018, 11:30 PM   #124
Aatto's Avatar
Originally Posted by montana1 View Post
Hi Aatto,
Best,
Rich
interesting read, and I totally missed that thank you.
Old 4th October 2018, 12:30 AM   #125
Aatto's Avatar
AE TD6M reportedly has some unusual dip around 900-1K Hz range, AE stock FR pic shows some dip in that area but apparently people are experiencing even deeper dip, looks like there are some fixes around this but not sure if this changes things or not.
4-Way Series Crossover. Accuton and Acoustic Elegance Drivers
Lambda TD6 tests on the way
Old 4th October 2018, 12:47 AM   #126
mordikai is offline mordikai  United States
Send a message via Yahoo to mordikai
I believe they have changed the design some what since then, but I would not trust that mid without some current measurements and user feedback.
Their woofers I trust because there is lots of user feed back, but the mids too much of a mystery for me at this point.
Why not one of the pro sound 6" mids? Looks like B&C have several interesting ones.
Old 4th October 2018, 04:28 AM   #127
Aatto's Avatar
Hopefully they did fix it by now, Cousin Billy showed how he did get rid off that dip (both here and on AE forum) apparently reflections from the magnet causes the dip and he explained how he got rid of that with a piece of Sorbothane, but the pic he shared does not help much, this goes back to 2015 tho and I could not find any newer info if they fixed the issue or not, they probably did otherwise people would still talk about it. but Cousin Billy mentioned that he liked it better than Accuton C158.
at the end of mentioned AE forum John from AE posted:
"There are clearly some changes as seen in the measured frequency response seen. I still have not been able to recreate this on a test baffle here. It is seen only in cabinets with approximately the same depth. The position of the dip does move with respect to depth of the cabinet though. Most all of these absorption techniques will help lessen any reflection off the inside of the cabinet. There could be a reflection from the lip around the spider, however adding a small amount of foam should not have that significant of an effect then with a resonance at that frequency.
At this point though, we have a new frame we are going to be using as the old one is no longer available. I will get some good measurements of the new driver on a test baffle soon."
Unfortunately this is the last post and no updates since hopefully the posted FR plot in TD6M is the updated measurement, the DIP is there but not significant.
Old 4th October 2018, 04:39 AM   #128
Aatto's Avatar
yeah Faital too, also heard good about 18 Sound 6ND430. any specific suggestions ?
hopefully the TD6M issue is taken care of, even with the dip issue it got all good reviews.
Old 4th October 2018, 05:22 AM   #129
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
About that dip around 700Hz, spider/frame reflections was suspected. I wouldn't trust Cousin Billy's sorbothane result too much though...
Most likely measuring a 6" driver with large plug at 3" distance is the main reason for the bad dip in first link. Even plug shape makes differences! Still, there is dip even in AE's owm data. This is partly compensated with typical baffle step hump.
Notice the difference in response nearfield (yellow)/1m (red)! TD6M - the Lambda Series Little Brother - AE Speakers
Wolfgang Klippel tells something here ... https://www.klippel.de/fileadmin/_mi..._Poster_01.pdf
Check this too, by Peter Larsen ! YouTube
Radikal aktivist AINOgradient speaker project
Old 4th October 2018, 05:26 AM   #130
Wayne1 is offline Wayne1  United States
There are some new drivers being released this weekend from nouaudio.
Dan Wiggins and Dusty from Channel Islands Audio are behind this effort.
The W130 looks like a good candidate for mid-woofer.
I will take a good look at it this weekend at RMAF
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 04:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 06:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 05:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 09:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 07:17 AM
Copyright ©1999-2019 diyAudio
