Open Source "Tower XL"
Old 2nd October 2018, 08:39 PM   #111
ILikeFoodz is offline ILikeFoodz  United States
If it is possible to meet the design goals using bass reflex rather than TL (or pseudo-MLTL), I would be inclined to say it would be better to stick with bass reflex. I think this because, if I remember correctly, it is also a design goal that this speaker be intended for someone newer to speaker building to pick up and build, and bass reflex is a more common, easier design to build and understand for the new DIYer, particularly if pseudo-MLTL is as picky and finicky as I've read that TL designs are with respect to stuffing.
Just my thoughts as a newer DIYer myself, but I would be more inclined to pick up a project that is simpler to get right at this point. Keep it simple!
Old 2nd October 2018, 09:06 PM   #112
Paul Vancluysen is offline Paul Vancluysen  Belgium
My opinion is also to choose for a concept that is well known for most of us, not too complex, low risk. TL is more difficult to optimize and less people are experienced in it.
Old 2nd October 2018, 09:25 PM   #113
Aatto is offline Aatto  United States
Aatto's Avatar
agreed, as much as i like to try a TL but it calls for more prototyping and it wouldn't be easy, we can try a TL after we done with bass reflex it would be a good study and also much easier since we already steps ahead.
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 2nd October 2018, 09:28 PM   #114
Aatto's Avatar
Originally Posted by LORDSANSUI View Post
Hi Paul,
Brian suggestion is not exactly a standard TL, it's more simple to simulated and to build as BR. Easy to simulate with Hornresp, he also has a worksheet in excell file. If this particualr design is welcome, he might help to optimize a proposal with the AE TD15X driver, so you and the others can compare the solutions. He use to help a lot in this forum.
off topic.
just thought of something, I have a WAW(FAST) w SBA woofer, maybe I can start a thread to design a TL or pseudo-MLTL around that, but for now i have to wait and see how this goes.
Old 2nd October 2018, 09:42 PM   #115
Aatto's Avatar
You can help "Open Source Monkey Box" here: GoFundMe
Old 2nd October 2018, 11:44 PM   #116
LORDSANSUI is offline LORDSANSUI  Brazil
done. 25 CHF
Old 3rd October 2018, 12:03 AM   #117
Originally Posted by Aatto View Post
you cann't have higher SPL than the driver itself, your result have 99db for 18Sound driver while the driver itself has only 97.
Sorry to disagree but a clarification is needed, the sentence above is wrong because technically is possible to achieve higher efficiency based on two things:
  • Space radiation
  • Enclosure type
Specifically for the 18Sound 15W750 simulation, the datasheet value was measured at free space (4pi) using 125L sealed box while the simulation was done using half-space (2pi) and bass reflex.
Old 3rd October 2018, 09:56 AM   #118
  • Space radiation
  • Enclosure type
The 18Sound 15W750 has a sensitivity of 99.5dB in half space if calulated out of the TSP parameters.
It is B4 basrelflex for Vb = 175 L and tuned at fB = 42 Hz, then F3 = 42 Hz.
Old 3rd October 2018, 04:14 PM   #119
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
done. 25 CHF
Great, thanks!
Group buy for augerpro waveguides for Scan Speak tweeters -- elliptical version -- circular version
Old 3rd October 2018, 05:50 PM   #120
Aatto's Avatar
  • Space radiation
  • Enclosure type
ok, thought we r done w this, we are not talking "technically", yes technically we can go active and achieve 100db from a 90db driver ! while at it we can also use dsp and eq and get the flattest respond too but it is not about this project and I assumed we are talking within this project and same goes with 18Sound driver, one would assume you are talking full space unless mentioned other wise, and if this helps and makes thing go faster yes you were right, technically that MAYBE possible and yes we can achieve 99db half space from a driver w 97db full space hope we can let go and move on now.
Open Source "Tower XL"Hide this!Advertise here!
BMS 8CN552 8" coax (Pair) "point source" Soldermizer Swap Meet 0 14th June 2017 05:10 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 07:31 PM
My next project open baffle 4way (15" 12" 10" econo waveguide) help charlie2 Multi-Way 21 28th September 2015 06:25 PM
Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted tiefbassuebertr Full Range 1 5th September 2014 10:17 AM
"open source" projects need to be done differently prairiemystic Forum Problems 10 5th March 2010 08:17 AM
Copyright ©1999-2019 diyAudio
