Ribbon Crossovers: Need help...
Old 18th September 2018, 01:35 PM   #41
lowmass is offline lowmass  United States
Yes its actually a good tweeter within its range, and IMO the design of the magnet/pole parts and the diaphragm are actually quite impressive. It may be a cheap looking execution BUT the design details of the parts that matter are unique and well done.
If I still had a pair I would probably try modifying by adding to the horn enough to extend its low end response a bit
Old 18th September 2018, 05:56 PM   #42
SanJoseMichael is offline SanJoseMichael  United States
What would you add to the horn? If the horn was slightly larger, would that extend low end? Would it also set the driver farther back in the cabinet potentially causing some sort of time alignment issue?
Old 18th September 2018, 08:32 PM   #43
yes I would try making the horn a bit bigger. Idea is to get a more robust output down to maybe 3K hz if possible.
I have done this with a few ribbons and the results have been good. Didnt make tru horns but just larger "wave guides". No formulas or theory. I just set up measurement system and used cardboard cutouts and duct tape till I got a size shape that gave a good result. These gave the boost at lower end without too much loss at higher freq.
the larger deeper "horn" would set the ribbon back farther which will likely bring ribbon closer to the cones voice coil position which is a better time alignment.
The only concern with going a bit lower with that design is the transformer. Its quite small and its core may not be able to handle the power.
Ribbon Crossovers: Need help...Hide this!Advertise here!
SIT 1 and crossovers rickmcinnis Pass Labs 29 20th October 2017 04:49 PM
Crossovers which one? crash999 Multi-Way 14 23rd December 2016 10:27 AM
DIY ribbon info requested (constructing a ribbon unit) SpinMonster Planars & Exotics 15 11th April 2011 09:27 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 09:50 AM
Different Crossovers Dan_Sheets Multi-Way 5 9th February 2005 11:06 PM
Copyright ©1999-2019 diyAudio
