DATS V2: Vas Measurement-Coaxial Driver
Old 12th September 2018, 08:03 PM   #1
StefanWajs is offline StefanWajs  United States
Question DATS V2: Vas Measurement-Coaxial Driver
To measure the Vas of a driver one must input a driver diameter (cone + ½ of the surround), from which, I assume, that DATS calculates the effective cone area used in the Vas calculation. I am in the process of measuring the TS parameters of a KEF SP1587 “Uni-Q” (coaxial) driver. My question is: would it accurate to use a calculated ‘effective diameter’ based upon normally measured diameter minus coaxial tweeter diameter? (That is, convert the result of the two diameter measurements to a fictional effective ‘diameter’).
A second question did enter my mind: would it be more accurate to use to actual cone ‘surface area’ rather than ‘diameter’? (Although a bit more complex to measure, the surface area can be significantly different than an area based solely on the diameter, especially with ‘deep’ driver cones).
Old 13th September 2018, 01:16 AM   #2
ernperkins is offline ernperkins  United States
ernperkins's Avatar
Unfortunately you can't just subtract diameters to determine the effective Sd because Sd is related to the square of the diameter. Use D(effective) = square root of (Dwoofer (squared) - Dtweeter(squared)). Use that diameter value for DATS.
IIRC the SP1587 is the driver in the Q100 speaker. If so, a couple of other people have already measured it:LINK1 and LINK2. Search for Q100 in LINK2.
Old 13th September 2018, 01:43 AM   #3
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Calculate the area of the outer driver normally, then subtract the area (not the diameter) of the inner driver. This will give you the area of the donut.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 13th September 2018, 06:47 PM   #4
Thanks for your very helpful reply re SP1587; both 'links' were extremely detailed/helpful. I will compare my TS measurements with those presented (especially the woofer cone area).
Old 13th September 2018, 06:51 PM   #5
Thanks for your reply. That is the method I would normally use. However, I still have a question re that 'donut' method versus measuring and using the actual cone area.
Old 13th September 2018, 08:13 PM   #6
Pallas is offline Pallas  Pakistan
That can’t be right. Both of those put the driver sensitivity under the observed system sensitivity. See KEF Q900 Speaker System HT Labs Measures | Sound & Vision
Serious Audio Blog
Old 13th September 2018, 10:17 PM   #7
You can go either way, but as others have noted, the T/s parameters are a good guide, but not gospel, for speaker alignment, especially with various amounts of stuffing.
Don't spend too much time trying to attain 0.0001% resolution, and instead spend it measuring the results empirically.
Best,
E
Old 14th September 2018, 05:04 AM   #8
I repeat, a technique that determines a raw woofer has a lower sensitivity than the commercial system employing that woofer is not valid as to that woofer.
Serious Audio Blog
Old 14th September 2018, 10:31 AM   #9
TMM is offline TMM  Australia
Send a message via AIM to TMM
You should not trust the efficiency number calculated from an impedance measurement. In addition, this number is typically calculated at 1Watt instead of at a fixed input voltage so it somewhat meaningless for a driver that does not have a resistive 8ohm impedance. The fact that T/S model is only a 1st order approximation adds further inaccuracy.
To determine the sensitivity look no futher than a frequency response measurement at 2.83V/1m. I trust Zaph's measurement to be accurate here: about 89dB around Zmin (~200Hz). This is inline with KEFs own spec of 86dB for the Q100 once you factor in a few dB of baffle step compensation.
As with all systems, you should measure the actual woofer and tweeter yourself, at the same time in order to to gauge the difference in sensitivity and design the crossover. There is too much error in T/S efficiencies, measurement system calibration and driver production variation to do it any other way.
Old 14th September 2018, 02:23 PM   #10
ernperkins's Avatar
(I guess TMM responds quicker than I do!)
What you're seeing is the old 1W/1m vs 2.83V/1m difference in measuring SPL. If you look at Zaph's T/S parameters you'll see 83.92 dB efficiency and a DC resistance of 3.0 ohms. Here's what he says about his T/S measurements:
"Also note that the SPL number on the T/S parameters is an efficiency number based on one watt. Additionally, this number is calculated rather than actual. The SPL shown on the response graphs is a sensitivity number based on 2.83 volts and is actual rather than calculated."
On the other hand, the Sound & Vision article states: "All passive loudspeakers were measured with grilles at a distance of 1 meter with a 2.83-volt input and scaled for display purposes." And it also states that the Q100 sensitivity to is "88 dB from 500 Hz to 2 kHz."
By my calculations the difference between 1W and 2.83V for a speaker with a DC resistance of 3 ohms is a tad over 4 dB, changing Zaph's 1W value of 83.92 dB to about 88 dB. This matches closely to the measured SPL in his frequency response graph which is done at 2.83V.
DATS V2: Vas Measurement-Coaxial DriverHide this!Advertise here!
DATS measurement of 15w8530K01, odd? Kev06 Multi-Way 21 9th January 2015 02:30 AM
Coaxial Compression driver hugobors Multi-Way 5 27th September 2011 06:21 PM
Tannoy Coaxial driver Ipanema Multi-Way 6 15th June 2011 03:03 PM
coaxial full range driver hans p Multi-Way 2 6th November 2008 12:24 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 01:09 AM
Copyright ©1999-2019 diyAudio
