DIY High End Studio Monitors
Old 13th September 2018, 12:51 AM   #71
Alex Music is offline Alex Music  Romania
D165 ar QTS=0.30
Can be used in the sealed enclosure?
Old 13th September 2018, 03:07 AM   #72
kii Three have 70 ms latency, that is not good for live tracking.
From this moment I remove the kii three design.
I will build my monitors according to the Barefoot or Dutch & Dutch design.
Latency (delaying the signal between input and output):
Kii Three = 90ms (Why so much?)
Dutch & Dutch 8C = 34ms (Why so much?)
Barefoot = 1.5ms (~0.5m)
Am I wrong?
Old 13th September 2018, 03:40 AM   #73
mitchba is offline mitchba  Canada
mitchba's Avatar
Both the Kii THREE and D&D 8c have a low latency mode of operation of ~1ms, which makes them fine for tracking.
Time alignment of drivers and the bounce off the front wall, requires a linear phase FIR filter which means latency. Which is fine for mixing/mastering music.
Here is the difference in step (i.e. timing) response for the Kii's in phase linear and mininmum latency modes: Kii Audio Three loudspeaker Measurements | Stereophile.com
Old 13th September 2018, 10:37 AM   #74
Charles Darwin is offline Charles Darwin  United Kingdom
Originally Posted by krivium View Post
Charles, sure we agree share some things in common... modular, nearfield,Tannoy i'm sure we have a lot of lp in common too...
I'd be very surprised if there were no overlap in our record collections!
I'd also be (pleasantly) surprised if there were a lot though.
As for the subject of this thread I am not a great fan of a lot of DSP processing so I shall keep out of this on the whole.
Old 13th September 2018, 02:14 PM   #75
plasnu is offline plasnu  United States
Originally Posted by electrisizer View Post
ive done some ATC/Quested 3 way Studio monitors and they are impressive! activated by Hypex fusion amp 253. Got the Drivers from A.O.S (Volt, scan speak).
Amphion!
What is the green outboard above 1176?
Old 13th September 2018, 02:21 PM   #76
spendormania, I read the German forum about your Kii clone (Google translated). What a journey. Congrats.
Old 13th September 2018, 03:07 PM   #77
krivium is offline krivium  France
Plasnu: i will play at "guess what the greeny is".
My answer:[Silent:arts]'s Dla-2a electrisizer's own implementation.
Harder is the 1u rack between the greeny and revA... i guess it is a... IJR Mixbuzz1!
What did i won?
More seriously both are (very) nice compressors. Dual la2a and a Ssl4000e/g mixbus comp variation.
Old 14th September 2018, 09:14 AM   #78
spendormania is offline spendormania  Germany
Originally Posted by Alex Music View Post
D165 ar QTS=0.30
Without hesitations. These are outstanding bass drivers!
Thank you. I had to learn a lot, but it was worth it.
Old 14th September 2018, 11:16 AM   #79
electrisizer is offline electrisizer
What did i won?
GOT it man!!!!
the ssl 4000 style is the SB4000, IJR is very similar... i like DIY the studio stuff. especially building microphones is fun and let you create very high end sounding studio gear...
consider: you cant soffit mount speakers like Kii or 8c - if you want to go this route you better choose a classic speaker design.
Old 14th September 2018, 10:20 PM   #80
Very Nice
Yeah, soffit...
DIY High End Studio MonitorsHide this!Advertise here!
Fane Studio 5M+5FR - in use by which commercial Studio Monitors ?? tiefbassuebertr Full Range 9 2nd May 2015 09:13 AM
DIY passive studio monitors + amp, mod cheap monitors? jdominicjackson Full Range 11 11th June 2014 06:29 AM
AS studio monitors forart.eu Multi-Way 18 4th January 2014 12:12 PM
Has anyone attempted to build high end studio monitors? Optical Multi-Way 14 9th September 2004 04:00 AM
studio monitors RyanC Multi-Way 26 29th April 2004 03:27 AM
Copyright ©1999-2019 diyAudio
