Nearfield Monitors with 5 or 6.5" woofer
Old 8th September 2018, 06:21 PM   #11
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Default an Oldie Davis 13KLV5(M)A
Hi gug,
may a bit idea to older speaker.
I like the Davis 5", it is real a very old chassis, it has 91dB/spl and goes to 57Hz in ~7liter vented volume and is linear to 4kHz.
Newer chassis you would difficult find all combined.
My tests are based on B. Timmermanns construction in late 90'is.
I have experimented with Expolinear RT-4Pro and finally a result what i like to
listen.
Many other options with own magic possible.
Davis Lautsprecher 13KLV5A | Lautsprecher Intertechnik - Shop
send from my NOTEBOOK PC.
Old 8th September 2018, 06:40 PM   #12
gug42 is offline gug42
Hello,
Thx, Seems a real woofer : DAVIS ACOUSTICS 13KLV5A DATA_SHEET
Sadly a little too pricy ... in second hand market ?
Old 8th September 2018, 07:07 PM   #13
Roby60 is offline Roby60
hello,
promo here : DAVIS ACOUSTICS 13KLV5A Haut-Parleur Bas Medium Kevlar 50W 8 Ohm O 13cm - Audiophonics
or take a look on french forum, it's a classic
Old 8th September 2018, 07:43 PM   #14
Hello,
I will look Sadly if audiophonics does'nt have in stock ... they rarely can get it later.
Old 8th September 2018, 08:55 PM   #15
Bangla H's Avatar
Default more budget options
these examples have not that searched spl.
On my list ScaMo in Ellam case.
Ellam-Discovery-15
Strassacker, Komponenten: Lautsprecher, Frequenzweichen, Bauelemente, only 85dB, but if you know scan speak.....
DAU Mino_M- here i like the waveguide- more omnidirectional.
DAUmino „M“ – 40 Hz aus 8 Litern – Donhighend Audio
Best Price for old Davis i could found here:
DavisHp
May it helps a bit.
Regards.
Old 8th September 2018, 09:36 PM   #16
Thank you I will look at them !
Well I have look to davis speaker, they seems great ! Even for small sized.
Hum I'm thinking about the Rabbitz Sopranos-Write-up-A.pdf
Seems pretty cool too ! And small for sure
Old 9th September 2018, 02:48 AM   #17
LineSource is offline LineSource  United States
LineSource's Avatar
PORTS SUCK! they also blow... whistle... huff and puff.... leak midrange harmonics.... generate phase shifts
TID....BIT.... Put a 6.5" SB17MFC35-8 midwoofer in a sealed 0.6cuft cabinet and you will experience excellent transients from 2,300Hz down to -F3=62Hz before room gain.
As part of your decision tree... Have you compared sealed vs. ported nearfield speakers?
Old 9th September 2018, 06:47 PM   #18
Bangla H's Avatar
Exclamation SB17MFC
I have visit Zaph webpage to read about ZD5- sealed cabinet 0,5cuft has my attention.
You can see in my pic underneath Davis a old Seas W210NP in a sealed 1,2cuft (32Liter) cabinet, F3 ~ 60Hz.
Since i have sold it to a good Friend i was searching a speaker who would do a
good job like that one.
Thanks for info form SB17MFC, lineSource.
I agree your points with impressions, experience in listening to my Seas monitor.
The SB17MFC is a candidate since i read about Jeff Bagby's Tributes with balanced crossover.
Would it work in sealed cabinet too?
Jeff Bagby's Tributes Build
From meeting: YouTube
Old 9th September 2018, 07:00 PM   #19
Bangla H's Avatar
Ah found that to Troels Gravesen SBAcoustics 61-MFC with very good Tweeter.
SBAcoustics-61-MFC
So you can go sealed or vented in 17 Liter cabinet.
Old 10th September 2018, 05:54 PM   #20
LineSource's Avatar
1) A cabinet design with 20-21 Liters (0.7-0.75cuft) completely empty, ends up close to 17 Liters (0.6cuft) after adding the speakers + crossover parts + bracing + port tube. Internal sound absorption material like fiberglass and wool will increase the effective volume.
2) For greater usage flexibilty, you can include a port which is easy to plug, or easy to unscrew and remove.
--sealed 0.6ft^3 produces -F3 =62Hz
--Post #5 ported 0.6ft^3 produces -F3 =48Hz (2" internal diameter pipe, 11" long)
--studio monitors typically favor a front port for direct impact, home speakers typically favor a rear port for room intergration.
3) Bevels or Rounds... on top monitor cabinets. Reducing edge diffraction distortion is worth the effort to cut top edge bevels around the tweeter as in Post #5, or use a router to round the cabinet edges. A router with a 0.5" chuck can run a 1.5" radius quarter round bit. A 2xThick baffle is required.
Nearfield Monitors with 5 or 6.5" wooferHide this!Advertise here!
Studio Monitors (nearfield) - around the NeoPro5i AdamZuf Multi-Way 57 4th June 2007 11:02 PM
recording/mixing nearfield monitors ogulinoglo Multi-Way 3 14th June 2004 11:03 PM
Taking a hack at nearfield monitors Freakaccident Multi-Way 42 27th November 2002 07:44 AM
re: nearfield monitors jeantofte Multi-Way 5 12th October 2002 11:27 AM
Copyright ©1999-2019 diyAudio
