PMC BB5 passive crossover schematic info wanted
Old 6th September 2018, 12:15 PM   #1
darkmatter is offline darkmatter  United Kingdom
darkmatter's Avatar
Question PMC BB5 passive crossover schematic info wanted
I am looking for any details or information concerning the crossover schematic for the PMC BB5 passive monitor speaker system.
Obviously this will have to be from someone who has reverse engineered or traced the crossover circuit, as such information is copyrighted.
A layout of the components would be a great help.
Pics of the speaker here
PM or post if you can help
Old 6th September 2018, 12:25 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I think you will find that information has copyright.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 6th September 2018, 01:29 PM   #3
Charles Darwin is online now Charles Darwin  United Kingdom
Besides copyright you would need the PMC mid dome which is not actually for sale.
Old 6th September 2018, 08:19 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Yes, XO map drawn by PMC will be copyright, but maybe someone has reverse engineered the XO. It is at least worth some theoretical value and would be interesting to see.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th September 2018, 12:48 PM   #5
darkmatter's Avatar
dave
Thanks planet10, I will only be seeking information that has been reverse engineered or traced, I do not want to fall foul of any copyright infringement.
The information is for guidance only, as I want to find out the bandpass topology used for the midrange, I think it has 4th order electrical slopes.
Thanks,
DM
Old 7th September 2018, 01:46 PM   #6
system7 is offline system7  United Kingdom
system7's Avatar
Ah, we are unlocked again.
We did a huge and largely pointless thread on the similar Wilmslow Audio Prestige.
FLOOR-STANDING Loudspeakers
It's actually a difficult speaker. But uses 12" Volt bass and 3" Volt dome mid. 750Hz and 3kHz XO, I'd guess.
I have a typical circuit from that thread below. It actually modelled horribly. The dome mid doesn't play nicely with the bass slopes on simple filter. I'd never be tempted by a speaker of this type given a regular cone mid or two works so well.
File Type: jpg Wilmslow Audio Presige juancho version 16 ohms.JPG (46.2 KB, 83 views)
Best Regards from Steve in Portsmouth, UK.
Old 9th September 2018, 12:46 PM   #7
darkmatter's Avatar
Indeed the curcuit design using the VM752 mid was way out in my view, the WM752 unit needs 3rd or 4th order electrical slopes as a minimum. The ATC mid used in the schematic you posted is a completely different unit in all respects. I will revisit the thread for reference only.
Old 20th September 2018, 03:02 PM   #8
cyte is offline cyte  United Kingdom
The schematic and PCB are proprietary and copyrighted.
PMC state in their marketing that their 3-way passive crossovers are 4th order Linkwitz-Riley.
That's really all you need to know.
PMC BB5 passive crossover schematic info wantedHide this!Advertise here!
Threshold PCX Crossover Info wanted.. Daveis Pass Labs 18 18th December 2015 12:21 AM
Need info on building 3 way passive crossover Darrylmcl22 Car Audio 10 20th February 2014 09:56 AM
JBL LX800 Schematic from the Crossover Network wanted tiefbassuebertr Multi-Way 0 8th February 2014 12:31 AM
Thiel CS-2 (CS2) - Schematic for Crossover Network wanted tiefbassuebertr Multi-Way 9 16th January 2014 10:52 PM
4 ohm - 3-way passive crossover wanted eljefe98 Everything Else 2 25th August 2006 02:33 PM
