Modular active 3 way - work in progress
Old 7th September 2018, 03:48 AM   #21
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Originally Posted by DonVK View Post
Interestingly. The first time I saw the IR for a passive LR4 , I spent at least a week (with DIYaudio help) trying to determine what was wrong with it. It turned out it was suppose to look like that by design. I even measured 4 different commercial speakers that I own (and like) and all of them had very messy IR and steps.
Is that for three ways, or two ways as well? My two way with 4th order bessel acoustic slopes seems to have a pretty reasonable (to my limited understanding) step response....
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 7th September 2018, 04:11 AM   #22
DonVK is offline DonVK  Canada
DonVK's Avatar
It was both 2 way and 3 way, but the 3 way was worse. Have a look OmniDirectional - work in progress It was a surprise to me.
The passive LR4 was in my 2 way at OmniDirectional - work in progress
Old 7th September 2018, 08:21 AM   #23
Boden is offline Boden  Netherlands
Hello Don,
Thanx for the overlays. It now shows the driver plus textbook filter do not enitirely match. That is what the Big Four (Calsod, Leap, SoundEasy& LspCAD) have optimizer s for. Yet, I am positively surprised about the results. Nice work!
Eelco
Old 7th September 2018, 09:07 AM   #24
just another
wintermute's Avatar
OK thanks Don, is the dramatic improvement in your before and after shots mainly due to delay bringing the drivers into time alignment? How does such a dramatic difference in objective measurement sound subjectively?
Tony.
Old 7th September 2018, 12:48 PM   #25
DonVK's Avatar
Yes, the phase compensation is mostly time aligning the driver outputs after all the gain EQ and XO induced delays.
The IR and Step of single drivers are relatively good (but not perfect). I implement separate gain and phase compensations even though they could be combined. The gain adjustments are via equalizer and the effects (if >2dB) are easily noticed when you turn them on/off. The phase compensation is unity gain via FIR convolution and can also be separately turned on/off. However, I find the phase compensation effects much harder to describe because they show up in more subtle ways. Acoustic instruments seem a little more real (detail, attack), if that makes any sense. BTW I still like my commercial speakers even after I measured and discovered their "flaw".
I might try moving the speaker sections forward/backward to see if I can "manually" time align the drivers. I see some speakers where they align the voice coils vertically.
Late post : I only have one test speaker now. So I can't comment on other important phase related details like imaging and sound stage.
Old 7th September 2018, 01:02 PM   #26
just another
wintermute's Avatar
Yes it would be interesting to see whether physical time alignment will bring the step response close to what you have achieved with the FIR. I've read that to get a step response like your corrected one you need a transient perfect crossover, which I don't think you can do except with first order? So I'm interested to see results of any experiments you do
edit: doing a bit of searching after posting, it would appear that 2nd order LR are actually transient perfect, but higher orders not so.
Tony.
Last edited by wintermute; 7th September 2018 at 01:13 PM. Reason: add comment on 2nd order.
Old 7th September 2018, 01:25 PM   #27
DonVK's Avatar
Experiments and musings will be posted
Old 7th September 2018, 05:16 PM   #28
DonVK's Avatar
Default driver jenga
I was curious to see if I could effect the same IR & Step cleanup by shifting the drivers to time align them. The problem is a single distance but the wavelength variation is infinite. Pics#1*#2 show the drivers are shifted in the Z-axis only.
Pic#3 is the FR with EQ only, then overlaid with the EQ+PH corrections on. You can see that I can change phase without effecting the FR shape.
Pic#4 & #5 are a comparison with flat baffle vs voice coil alignment. It makes a little difference but not much. I require more phase adjustment than simple driver shifting can provide. It also is causing more diffraction and a bumpy FR from the front steps. Pic#6 & #7 are just some variations in IR and Step from various combinations that I tried. Notice aligning VC's is a move in the right direction but it's not enough and it would only be the right correction for a narrow band(s) of frequencies.
Old 7th September 2018, 09:47 PM   #29
just another
wintermute's Avatar
Interesting! Could you also post the comparison of the FR with the phase. I'm assuming that with the phase adjusted it is pretty much a flat line across.. Much less of a difference with the time alignment than I was expecting
Tony.
Old 7th September 2018, 11:39 PM   #30
DonVK's Avatar
This is the graph for aligning the voice coils and is very similar to the aligned to baffle graph. You can see the amount of phase adjustment required to get back to a min phase response.
The LR4 may be phase aligned, but not in the same cycle. The LP shift is +360deg (4 * 90deg per order) and the HP is shifted -360deg, so there is a 2 cycle difference (-720deg LP to HP), even if they are "in phase".
Interestingly, you can select a distance that causes two drivers to be out of phase at a particular frequency and generate a null. Might come in handy for resonant drivers.
Late post : sometimes REW is off by a cycle, so in the 2nd graph the min phase should be centered on 0deg not -360deg (diff 1 cycle) and same with excess phase is sometimes 360deg (1 cycle) off. Don't know how to adj it, as all the curves move when you "add phase, +/-360deg".
File Type: jpg aligned to baffle with no PH adj FR + PH.jpg (112.8 KB, 80 views)
Last edited by DonVK; 8th September 2018 at 12:03 AM. Reason: left out a graph, cycle shift corr
Modular active 3 way - work in progressHide this!Advertise here!
Active modular 3 way shared design? webby Multi-Way 6 22nd April 2016 05:55 AM
Work in progress... Asio4All Q pcb121055 PC Based 3 25th November 2011 04:59 AM
Gaincline Bi-Amp / Active Crossover - work in progress gainphile Chip Amps 10 5th January 2008 11:35 PM
BZLS work in progress till Pass Labs 10 26th February 2004 07:34 AM
Aleph 5 - work in progress SuppersReady Pass Labs 23 14th November 2003 09:40 PM
Copyright ©1999-2019 diyAudio
