Modular active 3 way - work in progress
Old 6th August 2019, 04:12 AM   #101
DonVK is offline DonVK  Canada
DonVK's Avatar
Default two 8" woofers, two chambers
Two hours and $20 later I have a new woofer enclosure. This one was built for 2 SilverFlute W20RC3808 8" woofers to see if I can improve the bass/midbass response.
A quick run of HornResp provides Qtc=0.8 with about 20L/chamber (pic#1). So mine are actually 22L to account for the magnet and other material (acoustic tile + fiberglass) in the chamber (pic#2).
The measured individual woofer response is very close (pic#4) to HornResp. The THD (pic#5) is low and looks fine.
The system measured system response after level adjustment is show in pic#6, and #7. I've only had 1 hours to listen (@90dBc@1m) and it sounds good so far. I would prefer the woofers closer together and higher up near the midrange but I also don't want it any wider or deeper. Still thinking about how to do that.
File Type: jpg SPL SilverFlute W20RC3808 nearfield.jpg (96.0 KB, 174 views)
File Type: jpg THD SilverFlute W20RC3808 nearfield.jpg (105.2 KB, 170 views)
Old 7th August 2019, 07:18 PM   #102
DonVK's Avatar
I thought about it some more and and moved the woofers closer to the midrange. There are now two irregular chambers of equal volume (22L) that allow closer woofer spacing. Despite the different chamber shapes both woofers measure very close in the nearfield. Damping material is acoustic tile and fiberglass.
Old 7th August 2019, 10:02 PM   #103
Dave Bullet is offline Dave Bullet  New Zealand
Are you planning a 3 or 3.5 way? With a midrange xo point @ 725Hz - I wonder for a 3 way what lobing / issues might result with the lower woofer that far away from the midrange? Of course the impact will lessen (?) the further away the listening distance.
"Usual diyaudio train wreck of dubious drivers and just the crossover to sort out. Well, how are you on crossovers and modelling? Pretty green, I reckon" - system7 (Steve)
Old 7th August 2019, 10:53 PM   #104
DonVK's Avatar
Hi Dave,
The speaker is a 3 way with a BP6 sub beside it. The 8" woofers are in parallel and the wood space between top woofer and midrange perimeter is 3cm. So that leaves 20cm C-C between the mid and top woofer. The two woofers need to be considered together not independently (see below).
I listen at approx 2m from the speaker and have not noticed a problem yet, but it's still early I did have issues with the initial version so I changed it to push both woofers up.
Yes you can get some nearfield lobing, compare the BEM sim of a single 6.5" in Modular active 3 way - work in progress to the dual 6.5" in Modular active 3 way - work in progress .
Old 14th August 2019, 12:08 PM   #105
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
looks good Don, Did you use a sloping baffle between the two volumes? I was trying to think of a way you could achieve what you wanted, and you obviously worked it out!
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 14th August 2019, 12:47 PM   #106
DonVK's Avatar
Hi Tony,
Yes, the box is split diagonally using a sloping internal partition. I was pleasantly surprised that the near field's measured so close given the different chamber shapes.
Old 14th August 2019, 01:02 PM   #107
just another
wintermute's Avatar
I got as far as the sloping baffle and then started worrying about the asymmetry, it appears that it wasn't a problem! That's the great thing about doing actual experiments! Keep up the great work
Tony.
Modular active 3 way - work in progressHide this!Advertise here!
Active modular 3 way shared design? webby Multi-Way 6 22nd April 2016 05:55 AM
Work in progress... Asio4All Q pcb121055 PC Based 3 25th November 2011 04:59 AM
Gaincline Bi-Amp / Active Crossover - work in progress gainphile Chip Amps 10 5th January 2008 11:35 PM
BZLS work in progress till Pass Labs 10 26th February 2004 07:34 AM
Aleph 5 - work in progress SuppersReady Pass Labs 23 14th November 2003 09:40 PM
Copyright ©1999-2019 diyAudio
