MTM crossover concerns HELP required
Old 17th August 2018, 09:59 PM   #21
LineSource is offline LineSource  United States
LineSource's Avatar
Take a look at the Tang Band 5" W5-2143
-90db sensitivity.
-Mms = 6g,
-underhung motor,
-sim with 3kHz BW3 / BW3 crossover circuits
-Aluminum phase plug smooths sound above crossover
-Virgin white cone + Al phase plug blend with Al ribbon
The Scanspeak 18W/8434G00 has Resonance frequency [fs] 50 Hz, so putting two in a 2.5 cuft volume with a port tuned to 40Hz looks good for a modest 1.5db bass shelf with -F3=38Hz PORT = 4" inside diameter, 5.6" long simple pipe (no round overs). Tweeter height ~39" is desirable. Width and depth should not be the same.
You can reduce cabinet edge diffraction distortion with simple edge bevels, or if you have a router with a 0.5" chuck you can purchase up to 1.5" radius quarter round cutters.
Old 17th August 2018, 10:03 PM   #22
FluxRemover is offline FluxRemover
Banned
Originally Posted by system7 View Post
I really don't know if eriksquires' design translates well to MTM with those scan 6" of yours. You'd have to model it.
Thanks, something I should also look into and I will.
Edit: I will look at this right now...
Old 17th August 2018, 10:08 PM   #23
Banned
Originally Posted by LineSource View Post
Take a look at the Tang Band 5" W5-2143....
Somebody else just emailed me and suggested something similar from HiVi...
Old 18th August 2018, 09:34 AM   #24
kimmosto is offline kimmosto  Finland
kimmosto's Avatar
I've designed few MTMs with NeoCd3 and 5.25" Seas paper cones. Xo was close to acoustical LR4 at 4kHz. Overall compromise around xo; balance, flexibility and spl capacity is better than textbook bw3+bw3 quite often recommended here. It's good to be aware of textbook designs but better applications irl are possible.
MTM crossover concerns HELP requiredHide this!Advertise here!
Speaker crossover concerns woody Pass Labs 1 28th March 2015 03:02 PM
Crossover required. underwurlde Multi-Way 5 22nd April 2011 11:44 AM
Crossover help required zebra100 Multi-Way 11 15th December 2008 02:52 PM
Crossover Concerns... (NSB - sorry guys) Mjr7531 Multi-Way 24 18th January 2005 04:14 AM
Crossover/box concerns hi_im_sean Multi-Way 2 26th September 2004 02:27 AM
Copyright ©1999-2019 diyAudio
