SB Acoustics Satori MTM: MW16P-8 + TW29BN-B
Old Today, 01:03 AM   #11
88man is offline 88man  United States
Originally Posted by stretchneck View Post
How do they compare with your GeerS eVe II style speakers that you also have pictured which is using the Scanspeak Illuminator mid?
The Geers eVe II uses the ScanSpeak Classic line drivers - 21/8555-01, 18W/8545, D2904-98000 in a 2.5-way, series-fed mid/tweeter, parallel woofer. The Mundorf Supreme Caps sound amazing with the paper/carbon cones. These have more holography, dimensionality, dynamics, and spaciousness than the SBA MTM 16. The high efficiency of the eVes match well with tube or solid state gear. 2.5-way strikes the best balance in sound quality, naturalness, and musical experience. I'm actually going to make a Satori eVe version of this 2.5-way using the ScanSpeak 22W/8851T00, SB MW16P-8, and TW29BN-B.
The MTM crossover includes the Jantzen Alumen Z. The MTM excels in transparency and naturalness. The Be tweeter is smooth and airy. The D'Appolito design yields limited vertical dispersion, but excels in horizontal dispersion - so keep tweeter @ ear level on stands!
The custom 13" 3-way uses Visaton TIW-300, 18WU/8741T00, D3004/66000. Crossover is a series-fed 3-way mid/tweeter with parallel woofer. Large mid caps are the Jantzen Superior Z, and the tweeter caps are Audyn Reference and Mundorf Silver/Oil. These excel in throwing an even a larger image, dynamics, and frequency extension over the MTM. 13in 3-way matches better with solid state than tube gear due to the lower 86dB SPL.
The efficient SBA MTM matches better to my 6SN7 tube preamp, and push-pull KT88 amp setup than my solid state Odyssey Tempest preamp and Dual Mono Amp gear. The
SB Acoustics Satori MTM: MW16P-8 + TW29BN-BHide this!Advertise here!
2 way for SB Acoustics “Satori” MW16P-4 mid-woofer ckwong99 Multi-Way 9 19th February 2018 09:17 AM
FS: BNIB SB Acoustics Satori MW16P-8 bikinpunk Swap Meet 1 22nd June 2015 04:27 PM
Group Buy: SB Acoustics Satori 6" MW16P-8 bikinpunk Group Buys 3 9th June 2015 04:50 PM
FS SB ACOUSTICS SATORI MW16P-4 + TW29R NEW johhanson Swap Meet 16 7th November 2013 01:34 PM
SB Acoustics Satori MW16P-4 Measurements! gornir Multi-Way 18 24th June 2013 08:29 AM
