Hi guys
I am building a 100W amp for my guitar amp. It can drive 4 to 8 ohm speakers, I read
I am looking at a 10" Woofer and a Small tweeter both are over 60W each. Both are 8 ohms
This seems to be the data on the 2 x speakers
Larger Pic Here
The questions are: Will I need additional Caps or Chokes on this setup?
Will I need a crossover? Is it something I can make myself.
I am pretty new here, please go easy
Thank you
Regards Dez
Larger Pic Here
Thank you
Regards Dez
You need at least a capacitor connected serially to the tweeter. Is this intended for bass guitar? If not, woofer+tweeter is wrong concept, there are dedicated guitar loudspeakers:
Guitar / Bass | Eminence Speaker
Products - Jensen
Products - Jensen
1st: You may not like the sound of an additional tweeter in a guitar speaker cabinet, as it literally may blast your eardrums (basically the same as said before).
2nd: A 60 watts speaker connected to a 100 watt guitar amp most probably won't survive very long.
Best regards!
Best regards!
