“Building the best 3-way full range speaker in the world”
Saw your post on Facebook, and as stated there - stellar work :)
And if it gives you "chills and goosebumps" then its a definite success!
Regarding overall cost / amount of work... Pi is a very good factor.
Projected cost and time estimate multiplied with 3.14 are usually closer to the truth than the initial forecast :rolleyes:
A lot of projects would never have been initiated / attempted had the true cost been known.
But when its worth is - priceless :xmastree:
I am setting up a 3 way horn the mid has been the most difficult; best so far JBL compression driver made in Brazil. the horn bass speaker should be crossed over at 250HZ. horn loaded 8 inch speaker 8 watts is also very good hope to try a second hand JBL or 8 inch Chinese speaker 400 watts with the same specs. sounds good but I don't have speaker test equipment.
