Crossover exercise !
Old 15th September 2018, 05:00 PM   #31
Aatto is offline Aatto  United States
Aatto's Avatar
Default One more...
haha, I m not actually gonna invest into it until I get things right and i m not in a hurry, just a goal for now, anyhow I m not going to bore you with sending a crossover after another one, I will comeback when I have better understanding, one question tho, I used Jeff Bagby Crossover Design sheet this time, all 2nd order LR, at 250Hz and 2000Hz, with mentioned drivers, in JB XO sheet if I introduce 3cm z offset between tweeter and woofer (acoustic offset) and reverse the tweeter I can get rid of dip caused by the offset and get a flatish FR (work in progress) but when I simulate it in xsim, everything looks good until I add 3cm to tweeter, reversing the polarity in xsim does not behave as it does in JB XO Sheet. am I missing something here ?
sorry bout all noob Qs.
I used to be with it, but then they changed what it was, and now what Im with isnt it. And whats it seems weird and scary to me. - Grandpa Simpsons.
Old 19th September 2018, 08:03 AM   #32
sesebe is offline sesebe  Romania
Going with the impedance under 4 ohm will destroy your amplifier.
Decrease C5 value and increase L5 value (L5>=8mH).
Increase L3 value and decrease C3 value.
Play with the values on these components until you get the desired shape but taking care to the impedance to be over 4ohm.
Old 19th September 2018, 05:57 PM   #33
Aatto's Avatar
I appreciate it sesebe, yes you are right, my whole approach toward this was completely wrong and I did bored people with my novice questions, but I did study more about this and will continue to, I will be back when i think i have more confidence.
Old 19th September 2018, 06:03 PM   #34
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Low impedance seems to be allowed, if the speaker is expensive enough, in six-digit class!
AINOgradient speaker project
Old 20th September 2018, 03:53 AM   #35
Aatto's Avatar
haha thanks, I will start looking for Impedance/Price Tag ratio curve then .
Old 20th September 2018, 08:05 AM   #36
Dave Bullet is offline Dave Bullet  New Zealand
Here's my 3 way "so far". it's taken a while to get to this point. You have to be persistent.
"Usual diyaudio train wreck of dubious drivers and just the crossover to sort out. Well, how are you on crossovers and modelling? Pretty green, I reckon" - system7 (Steve)
Old 20th September 2018, 08:07 AM   #37
I find 2nd order acoustic W-M provides higher impedance. I gave up on 4th order here regarding impedance. It was easier to make 2nd order work with phase tracking then 4th order impedance.
Old 20th September 2018, 02:35 PM   #38
Aatto's Avatar
very interesting, this helps a lot, thanks.
Crossover exercise !Hide this!Advertise here!
Thought Exercise: Submini Circlotron OTL Amp supersonik319 Tubes / Valves 1 8th January 2013 08:09 AM
Exercise: 'the best resistor at the right place'? jeepy Parts 0 25th November 2011 02:52 PM
The little exercise of bookshelf fung Multi-Way 1 7th April 2006 08:35 AM
I've got difficulties to solve this electronic exercise Bricolo Everything Else 13 5th June 2004 02:31 PM
