Hivi domes
Hivi domes
Old 14th September 2018, 02:12 PM   #21
adason is offline adason  United States
adason's Avatar
thanks ernperkins, I will have a look
I do want to see what other people did with hivi domes for inspiration
otherwise I measure, I listen, I modify, and listen and measure again, and again, till I am happy
Goal is as simple as crossover as possible, as flat fr response as possible, as well as phase response...I found it important too
As I posted as the beginning of this thread, hivi mid dome and tweeter dome measure surprisingly well with just cap on each, so I am surprised to see such complicated crossovers in place
not sure why is that needed
anyway, I measured 5.5" peerless dome I selected, I did select it based on required range and that its dome too, and it measured quite well. My measurements are close to the published, its useful for 50hz to ~2khz, it has one break up at 3kz, no too severe, but something I need to suppress, so I am thinking of 2nd order at 1 kz, then I will measure again and listen
Old 14th September 2018, 03:03 PM   #22
adason's Avatar
fr response
Old 14th September 2018, 03:07 PM   #23
boswald is offline boswald  United States
Hivi domes
Unless you play them at very high spl or push the mid low, the simple filters work very well.
I've been restoring some old 3ways with this sort of setup- the Scott s-15s.
Crossed simply at 1&4k they have 5" CTS mids in cans, so the mid is loafing and the extra low frequencies are easily handled.
In these the tweeters are the limiting factors, and they play loud better with a steeper rolloff.
I'm watching this project of yours, have been playing with the widerange 3.5" dome that Mad has- with HDS 5.25 instead, but you have a great look with all domes.
Old 14th September 2018, 04:25 PM   #24
adason's Avatar
I have always crossed Dayton domes at 900hz. Hivi will be at 1000hz. That should keep them happy. I never play hifi loud. That's what I have PA speakers for...
Old 14th September 2018, 05:35 PM   #25
Hivi domes
Exactly.
It's only those poor souls who must make one set of speakers do all jobs who have to worry.
Old 14th September 2018, 05:36 PM   #26
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
I xovered the DMN-A at 850Hz, IIRC, and it needed the Fs suppression for the lower range to remain undistorted. The top-end needed the zobel to help with the blend of the mid to tweeter. The resistor across the tweeter damps its Fs. The 4.7 ohms are for level, and the rest is just slope/order and knee damping.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 14th September 2018, 05:56 PM   #27
wolf_teeth's Avatar
Kinda neat getting a mention on a site with someone else's design because I also used it. I've not heard of that guy either, but I do know of Rob Elder and Lou Corragio (RIP).
Hong Nguyen also used it with an old Vifa M26, IIRC, the one with the weird woven phasing-style dustcap.
Later,
Wolf
Old 14th September 2018, 08:18 PM   #28
adason's Avatar
thanks for the info wolf...
I will keep you guys posted with progress, just be patient, too many projects going on at the same time
but I want to finish this one to perfection
Old Yesterday, 03:18 PM   #29
adason's Avatar
Made a small progress...started with peerless without the crossover, seen that 3kHz breakup, decided to use 2nd order filter to suppress it.
This is the result. Looks ok to me so far.
Old Yesterday, 03:20 PM   #30
adason's Avatar
Then I made some painting/surface strengthening. To match the look of HiVi domes.
Hivi domesHide this!Advertise here!
AMT vs Scanspeak Revelator Domes rhythmsandy Multi-Way 4 9th March 2016 08:48 PM
Domes Vs Ribbons Nusnud Multi-Way 15 5th July 2015 03:30 PM
Dynaudio D 54 Midrange Domes domtweaker Swap Meet 1 13th April 2013 01:14 AM
FS: ATC Domes and Alphacore Coils mgreene Swap Meet 14 18th July 2008 11:16 AM
Sound domes jan.didden Multi-Way 6 23rd August 2007 12:30 AM
