Seas Excel W18EX001 vs Scan-Speak 18M/4631T00
Old 5th August 2018, 10:07 AM   #191
3wayaddict is offline 3wayaddict  Netherlands
3wayaddict's Avatar
Originally Posted by Rokytheman View Post
In regards to vibrations, putting the tweeter in its own champer will not necessarily dampen vibrations - It will rather reduce back pressure which is normally not an issue at all.
SB made a so called "Two part aluminium faceplate with integrated mechanical decoupling".
Does the TW29BN also have this? I’m going to decouple the tweeters so I’ll have to put them I a sealed chamber anyway because my decoupling system isn’t quite airtight and even if it was it wouldn’t work in the same chamber with the woofers because the tweeter will start acting as a passive radiator which only makes the vibrations it experiences worse obviously. But it’s nice to know it has that feature.
When you do it, do it right. Go all out.
Old 5th August 2018, 10:12 AM   #192
3wayaddict's Avatar
Wait. Is the part of the tweeter like the motor and diaphragm truly decoupled like you would to decouple a driver to keep it from picking up vibrations?! If it seriously is truly decoupled I wouldn’t have to decouple the driver myself which wouldn’t have been a problem but it’s still way easier if I don’t have to. It also save some space because I don’t need to be able to stick my hand in the tweeter chamber to fit the decoupling system. Without the need of the decoupling system I can just make the tweeter chamber as slim as the driver.
Old 5th August 2018, 10:59 AM   #193
3wayaddict's Avatar
All those pros do make it very attractive. Those 4,5 dBs aremore difficult than 0 dB but are addressable in the crossover but on the other hand it has a flatter respons which (away from baffle step compensation) doesnít have to be adjusted so it will probably a simpler crossover at the end of the day. And then the internal decoupling and obviously the sound you say comes out of it. I think it might indeed be the best choice when I cross it low enough so the wavelength of the crossover frequency is bigger than the distance between the driver centres.
Oddly with a quantity of two theyíre actually less expensive than the 604010ís at Speaker&Co.
Old 5th August 2018, 11:08 AM   #194
3wayaddict's Avatar
Theyíre a lot cheaper actually. Two 604010ís at Speaker&Co are Ä628,76. Two TW29BN-Bís at Speaker&Co are Ä606,58 but at Compagnie Acoustique Belgique they are just Ä559,-. Compagnie Acoustique Belgique doesnít even have the 604010 but the Scan-Speak they do have is a lot more expensive than at Speaker&Co so the TW29BN-Bís actually are a lot cheaper.
Old 5th August 2018, 06:01 PM   #195
3wayaddict's Avatar
Again my new design now with one of, if not the best commercially available beryllium tweeter with internal mechanical decoupling and a slightly longer port for further improved bass response from the now two WO24P-8's in parallel!
File Type: png Schermafbeelding 2018-08-05 om 18.58.32.png (558.8 KB, 149 views)
Old 6th August 2018, 01:14 AM   #196
3wayaddict's Avatar
I just noticed the MR16P-4 actually has slightly less distortion and a slightly flatter response. It also has a higher sensitivity of 92 dB. I think it will be a better option actually. I'm sorry to start about the mids again but we didn't have much discussion about the MW vs MR right? There wasn't really a right or wrong. But now that I look at some measurements. The MR16P-4 actually seems slightly better.
Old 6th August 2018, 02:26 PM   #197
tonza75 is offline tonza75  Europe
Don't forget the imd distortion for the loudspeaker elements it's often not measured by some 3rd party publisher.
Old 7th August 2018, 01:03 AM   #198
mordikai is online now mordikai  United States
Send a message via Yahoo to mordikai
They have new 8ohm satori tweets that are 93db.
Old 7th August 2018, 10:06 AM   #199
sottomano is offline sottomano
Originally Posted by 3wayaddict View Post
[...]Does anybody have distortion graphs of the 602010? [...]
https://www.aos-lautsprecher.de/pdf/...4_602010HH.pdf
The distortion vs. level has been made at 1500Hz.
Quite a performer, I'd say, especially for those needing to cross over low.
Edit: It's about the dome tweeter, D3004/602010, and not his Ring Radiator Counterpart R3004/602010
Test here: https://www.hifisound.de/out/media/p...GJRg%3D%3D.pdf
I'd take the dome variant.
Old 7th August 2018, 12:11 PM   #200
Rokytheman is offline Rokytheman  Denmark
Does the TW29BN also have this? Iím going to decouple the tweeters so Iíll have to put them I a sealed chamber anyway because my decoupling system isnít quite airtight and even if it was it wouldnít work in the same chamber with the woofers because the tweeter will start acting as a passive radiator which only makes the vibrations it experiences worse obviously. But itís nice to know it has that feature.
Well, no. The tweeters will not work as a passive woofer. If the is air around the tweeters you will just have a higher air leakage. Not desirable though. Vibrations are a difficult topic, and many ways to work around it. Vibrations will not only come from the woofer, but also from the front baffle and the cabinet.
Seas Excel W18EX001 vs Scan-Speak 18M/4631T00Hide this!Advertise here!
nice speakers. Seas Excel and Scan Speak vactor Swap Meet 11 17th January 2015 04:05 PM
FS: Speakers (Scan Speak, Seas Excel), Electronics (Tube Amps, Preamps) etc. PHilgeman Swap Meet 8 28th October 2008 03:22 AM
FS SEAS Excel W18EX001 juno Swap Meet 10 18th October 2007 01:50 PM
F.S Scan Speak, Seas Excel, Fountek, Dynaudio Beau Swap Meet 11 23rd May 2007 04:45 AM
Seas H1224 alu compared to Excel W18EX001? cyclo Multi-Way 6 17th June 2005 02:31 AM
Copyright ©1999-2019 diyAudio
