My first two way (Markaudio+Dayton)
Old 12th October 2018, 08:11 PM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
That MDF is an ideal cabinet material is myth AFAIC. I will get lots of argument.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th October 2018, 09:27 AM   #32
peroz is offline peroz  Slovenia
I don't know from very much experience, but 2 pairs of FH3's I made, one with mdf and one with ply, the one made of mdf sounds a lot tighter. Everything else is identical - driver, stuffing, room. Could be my ply was subpar, but can't know for sure, it looked good enough to me when I worked with it.
Plus, the big weight is a plus, because I won't have to fear my kids will tip them over - the reason I had to retire my FH3s.
Speakers this size, made of hi-grade plywood could be expensive as fu** as well. It's MDF this time.
Old 13th October 2018, 11:35 PM   #33
chrisb is offline chrisb
Originally Posted by peroz View Post
Really? Because I read once that the absolute best material for speakers would be a combination of mdf and particle board, so If I doubled on the thickness of the mdf... the thing should be pretty darn solid, right.
Or I could make my cabine maker sweat a little and actually make a MDF+OSB sandwich
Any amp recomendations for a speaker like this?
LM1875 or LM3886 or some class D?
The absolute best? The internet abounds with some quite entertaining bloviations on the subject, but AFAIC there's no such thing -period
I've built lot of speakers of many different types over the past two decades, and would recommend Baltic Birch or equivalent - there's a much wider range in quality of sheet goods labeled as "plywood" than is the case for MDF & PB. As far as speaker go, MDF is great for patterns, spacers and jigs.
As for type of amp - within your short list of options there's quite a range of quality from which to choose. For cheap, it's hard to beat some of the small ClassD amps from folks like Topping, YJ, SURE, etc - I have several still in my stable. If you're up to building a kit, the most impressive units I've heard recently have been LM3886 chip amps designed by Tom Christiansen - specifically the composite Modulus86 and 686. Not all chimp amp designs take the specific device's idiosyncrasies into full consideration, with varying degrees of unintended consequences or long term reliability issues.
Here's a fun read on the topic:
Taming the LM3886 Chip Amplifier
on hiatus from active posting
My first two way (Markaudio+Dayton)Hide this!Advertise here!
For sale pair of Dayton Rs225 woofers and Dayton rs28f Tweeters viki_v2 Swap Meet 0 30th August 2013 06:24 PM
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
Vifa/Dayton/Dayton... First speaker for me, finally! alexcd Multi-Way 6 29th November 2006 10:54 PM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
