SEAS MR18 3-way
SEAS MR18 3-way
Old 9th November 2018, 07:31 AM   #11
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Originally Posted by jtgofish View Post
I would not waste my time on those woofers.They might be fine as subs but not much good above about 70hz.Moving mass is too high and BL [force factor] is too low for such a heavy cone/surround.They have very poor timing and sound soggy above that frequency range.
I have tried all sorts of loadings and boxes but the fundamental character never changed.I sold mine.
I got them cheap, second hand. We will see, xo will be around 2-300Hz LR2. Actually I am more concerned about the low end of MR18, must be careful with distortion.
Radikal aktivist AINOgradient speaker project
Old 9th November 2018, 07:35 AM   #12
Juhazi's Avatar
iperno,
You can use Loki xo as starting point. SEAS have used many different tweeters in their coaxials, and it can be changed easily. I have T18REX coaxials with aluminium tweeters workin as my home theater L/C/R. Xo is not Loki, but Finnish kit design AW-7
Old 13th November 2018, 06:18 PM   #13
iperno is offline iperno  Italy
Grazie, bel kit, lavora in pochi litri rispetto al loki.
La mia domanda è: i t17rex che posseggo hanno il woofer a 4 ohm, invece che 8 ohm come trovo su tutti i progetti, quali modifiche devo apportare ai crossover?
Devo cambiare i valori di condensatore e induttanza della parte passa basso per mantenere il taglio ai valori previsti?
Grazie.
Old 13th November 2018, 06:19 PM   #14
Thanks, nice kit, works in a few liters compared to the loki.
My question is: the t17rex I have have the 4 ohm woofer, instead of 8 ohms as I find on all the projects, what changes do I have to make to the crossovers?
Should I change the capacitor and inductance values of the low pass part to keep the cut at the expected values?
Thank you.
Old 13th November 2018, 06:42 PM   #15
Juhazi's Avatar
^Sorry, I don't know how to design passive crossovers! But yes, values must be different!
Perhaps someone else at this forum can help iperno?
Old 13th November 2018, 06:58 PM   #16
denbret is offline denbret  Canada
denbret's Avatar
Hi, I made several measurements and tests with the SB29NRX75-6 woofer.
The ideal xover cut is around 200hz in 12db.
At the top of 175hz, its energy decreases a lot. But at this frequency, the SB29 is excellent. Volume of 55 liters.
Old 18th November 2018, 07:09 PM   #17
Juhazi's Avatar
I have made some purchases for the project - IKEA Blanda bowls (one extra for prototyping) and a casting tube from Biltema. Here you can see them in my well equipped and organized laboratory and storage rooms!
Diameter of bowls is 28cm (inner volume 7,2L) and the tube is 31cm. I will cut the tube in two pieces and slice it longitudinally, then expand it with a blank of wood cut in trapezoid shape to make it a little wider at the bottom (volume 43L). Top and bottom plates will be cut naturally from Finnish birch plywood.
Old 21st November 2018, 05:41 PM   #18
Juhazi's Avatar
I installed the MR18 on a cut IKEA Blanda Matt ¤30cm bowl and took some preliminary measurements. The woofer has nasty 4kHz spike that must be attenuated by cone treatment or with eq. Serial 6.8uF cap makes tweeter's response easy to eq and protects it from pops.
Here is a link to album of this project, photos and measurements
MR18 3w Juhazi - Google Photos
Old 21st November 2018, 07:30 PM   #19
Juhazi's Avatar
More measurement of cone issue. Nearfield at various radii and on-axis at various distance, added in the shared google-folder that I linked in previous post.
Here nearfield 10mm from cone, midline, near center, middle and edge. Pretty smooth up to 2,5kHz...
Old 22nd November 2018, 11:19 AM   #20
Juhazi's Avatar
I cut the bottom plates today, from 30mm thich birch plywood. I will mount the woofer on the inside to leave room for legs. Outer diameter of the disc is 35cm, inner 25cm.
This will be quite a Scandinavian speaker! SEAS from Norway, SB Acoustics has Danish roots, box from Sweden and design from Finland. Then amp from Netherlands.
This reminds me of a story about Eurpean politcians flying back from United Nations meeting. In the middle of Northern Atlantic ocean the pilot tells that if three passengers don't jump off, the plane will sink in Atlantic because of too little petrol. First the Britain stands up and shouts "God save the Queen!" before jumping. Then the Frenchman shouts "Vive la Liberte!" and jumps out. After a while the Norwegian and the Finn grab the Swede and throw him out shouting "Heja Nordisk samarbete!"
SEAS MR18 3-wayHide this!Advertise here!
First pics of first build Seas 2-ways. Seas U18RNX/P, Seas 27TBFC/G. Stewart Holmes Multi-Way 24 1st May 2014 12:17 AM
Before I order the parts for the Zaph Seas L18 / Seas 27TBFCG speaker mr_push_pull Multi-Way 17 17th August 2012 04:34 AM
Aurasound MR18.4 (NS18) x2 azngotskills Swap Meet 23 22nd October 2011 04:06 AM
18" Aura MR18.4 subwoofer nwpadmax Swap Meet 0 2nd April 2008 08:02 PM
Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. Spasticteapot Swap Meet 2 7th March 2007 05:06 PM
Copyright ©1999-2019 diyAudio
