On-wall/in-wall speaker design for HT
Hey guys,
I'm in the process of building 5.1.4 HT as a part of the 4mx6m living room and a bit stuck with LCR speaker design. Speakers will be behind AT screen, can be up to 25 cm deep (9.5 inches) mounted on-wall or into false wall (can do both). Listening volumes are moderate, so sound quality is preferred over sensitivity.
The only suitable design I found so far is DIYSG HTM-series, where crossover assumes on-wall mount, but as far as I understand, HTMs put sensitivity on the first place. Can you please recommend other suitable designs with something like SS Illuminator or Revelator and crossover designed for on-wall/in-wall.
Thanks in advance.
