Smallest Footprint Horn and Driver that can reach 500hz
Old 24th September 2018, 12:24 AM   #191
Ro808 is offline Ro808  Netherlands
The K510 or K402...
are on top of my wishlist (too)
I am seriously considering to build a clone, somewhat bigger than the 510.
A clue for the horizontals (the sidewalls), albeit undersized for the throat:
Old 24th September 2018, 12:57 AM   #192
And here's another clue
Old 24th September 2018, 01:22 AM   #193
The 510 and 402 are waveguides, primarily because of the high expansion rate.
The throat section has got very little, if anything, in common with OSWG's.
It's more akin to JBL's Image Control Waveguides, only......different.
However, I wouldn't be surprised to discover that JBL engineers were "inspired by Klipsch" during the development phase of their latest waveguides.
Old 24th September 2018, 01:38 AM   #194
LORDSANSUI is offline LORDSANSUI  Brazil
Originally Posted by Ro808 View Post
It depends on the horn and the Phenolic driver, is this a Selenium or old JBL?
The phenolic one could be the Selenium D405. It can do 110dB 1W/1m at 500Hz slop at 12dB/oct, probably with 24dB/oct it can play at 300Hz
below the datasheet link in english
https://www.jblpro.com/ProductAttach..._SpecSheet.pdf
I'm curious about the results, I never did this alignment but in theory it work and has high efficiency.
If I had bass reflex subs, I probably would try mid with phenolic and high with TI, it would save some power amp.
Old 24th September 2018, 01:43 AM   #195
EarlK is offline EarlK  Canada
Smallest Footprint Horn and Driver that can reach 500hz-clue-jpg
Must be a "Protestant" horn
Old 24th September 2018, 02:00 AM   #196
I would rather mark it as "ecumenical"
Old 24th September 2018, 02:11 AM   #197
Good Answer!
Old 24th September 2018, 02:12 AM   #198
Search: "Bob Crites Cornscala".
Mid and HF drivers in this project are: JBL Selenium D405 and D220Ti.
With a -3 to -6dB slope towards the top-end, the D220Ti probably won't yell above the "smooth" midrange.
Old 24th September 2018, 03:13 AM   #199
With regards to the "smooth" midrange: provided you don't push the D405 too low.
500Hz seems already close to the limit and this will only work with a horn that's big enough.
The above applies under the assumption that the speakers will be used at home and not for PA.
Old 24th September 2018, 04:17 AM   #200
The Community M200 might be a better midrange driver, but apparently these are hard to find.
It's got a Mylar diaphragm which should go nicely with a Mylar domed B&C or similar driver on top.
Smallest Footprint Horn and Driver that can reach 500hzHide this!Advertise here!
Horn Help: 2" 400-500Hz Horn Justauby Multi-Way 6 12th October 2017 01:46 AM
Looking for a medium footprint ~6" driver back loaded horn design hugz Full Range 7 18th August 2016 05:42 PM
The smallest size compression driver and horn? Brisso57 Multi-Way 42 27th August 2015 05:24 AM
Can a single straight horn cover 50-500hz? steve71 Multi-Way 13 17th January 2008 04:33 PM
Horn from 500hz to 20khz, how hard? bigwill Multi-Way 30 5th February 2007 05:10 PM
