Smallest Footprint Horn and Driver that can reach 500 Hz
Old 24th September 2018, 10:23 AM   #201
phase_accurate is offline phase_accurate
I have Faital HF146 drivers on 18s XT1464 horns. This combination can be used 500Hz-ish but I would recommend to cross higher due to the much easier implementation of crossover target slopes. A current Setup has a crossover frequency of 650 Hz.
They go up quite nicely but I think also my age helps a lot in not missing upper Extension
Charles
Old 24th September 2018, 12:40 PM   #202
Ro808 is offline Ro808  Netherlands
The HF146 is a very nice driver. Is this on top of a 12" or 15"?
If I had to buy new drivers for a smaller cabinet, I'd probably opt for the 15PR400 with HF146 or HF204.
It's not that easy to find 15's with "oldskool specs" these days.
Beyma is one of the non-esoteric brands that still offers a few. Their Alu dome 755 comp. driver (CP-755Nd/AL) is magnificent as well.
Does anybody have experience with an Aluminium diaphragm in TAD 4001?
Old 24th September 2018, 01:24 PM   #203
Nevermind, found an old thread.
Old 24th September 2018, 03:07 PM   #204
It is between two 15".
Charles
Old 13th November 2018, 01:59 PM   #205
Antonfazer is offline Antonfazer  Sweden
Hello all,
Interesting thread.
I would like to ask opinions and advices here. I am building a home system with 15 JBL woofer for midbass which I plan to cross to horn compression driver at around 800-1000 hz. For compression driver I have already Renkus-Heinz SSD3301, which is vintage 2 throat driver with aluminum diaphragm and seems to have a good reputation as a driver for home audio. I have also a pair of Renkus-Heinz CBH820 horns which came with drivers. They do have a slot near the throat entrance. I have done some prototyping and listening with active crossover. I like the sound of the drivers when played from 1 to 4-5 khz and then crossed to a tweeter. However, there is still some honkyness coming from the horn audible when listening to more complex musical styles.
ftp://ftp.renkus-heinz.com/Legacy_Pr...BH820_data.pdf
I would like to ask if the CBH820 horn is a good option for home audio or should I look for something else? In Europe there are not so many options when it comes to 2 horns: Eminence H2EA, 18 Sound XR2064 and a few options from P.Audio like 2380.
As I mentioned, I liked the sound with a tweeter on the top covering from 5k and above. When running active I liked the sound with Illuminator silk dome tweeter, but it is certainly not an option for passive crossover due to sensitivity. So I am looking for a good solution for a super tweeter or a small horn with CD which sounds somewhat similar to dome tweeter but preferably more dynamic and with higher sensitivity.
I like the sound of vintage JBL studio monitors. There, 1 or 2 inch compression drivers were used with narrow exponential tube horns, like JBL h93 with acoustic lens on top. Some people dismount the lens and like the sound more. My question is, what are the pros and cons of such exponential tube horns for home use comparing to constant directivity wide horns?
I have some experience building speakers and amplifiers but horns is a new thing for me. Any advice would be much appreciated.
Old 19th December 2018, 07:45 PM   #206
The RH SSD 18.. and 33.. series are Renkus-Heinz take on pancake drivers.
Personally I haven't use any of these, but according to others the SSD's are indeed nice drivers.
Be careful with the diaphragms, because replacements are very hard to find and NLA.
First some data:
Old 19th December 2018, 08:40 PM   #207
Renkus-Heinz used the 3301 in several 2-way loudspeakers, despite the rather steep drop above 12kHz.
With some (excessive) EQ you might boost the 12-16 kHz range, but you won't get to 20kHz. I would probably settle for that.
But if you prefer a (super)tweeter I'd look at Beyma CP21, CP21F, CP22, CP25 for synergy between diaphragm materials.
Old 19th December 2018, 11:00 PM   #208
The CBH 820 is a "Constant-Beamwidth" horn as opposed to Renkus SSH range, which are exponential (and presumably better suited for hi-fi).
The CBH 820 was available in 2 versions:
1. CBH 820: 90H X 40V
2. CBH 820-6: 60H X 40V.
Despite the description 'Waveguide' in the literature, these aren't waveguides in the Geddes' sense of the word, apart from being short.
Due to the diffraction slot and many sharp edges these are literally HOM generators. The honky character you refer to is not surprising.
I am afraid these horns are rather useless for hi-fi at home.
An exponential round horn could work with the 3301s, but I wouldn't use it because of the very narrow beam > it'll probably shave your eyebrows.
File Type: jpg RH 1989 Full Line Catalog_Pagina_04.jpg (519.9 KB, 21 views)
Old 20th December 2018, 04:42 AM   #209
That said, it may be worthwhile to stick some 30ppi foam in the first (throat) part of the horns and attach some damping material to the exterior.
Old 20th December 2018, 03:25 PM   #210
On closer inspection, the throat area of the CBH 820 doesn't look all that bad. The transition from throat to mouth is similar to my B&C horns. However, the sharp edges between the segments remain a source of reflections/scattering.
Smallest Footprint Horn and Driver that can reach 500 HzHide this!Advertise here!
Horn Help: 2" 400-500Hz Horn Justauby Multi-Way 6 12th October 2017 01:46 AM
Looking for a medium footprint ~6" driver back loaded horn design hugz Full Range 7 18th August 2016 05:42 PM
The smallest size compression driver and horn? Brisso57 Multi-Way 42 27th August 2015 05:24 AM
Can a single straight horn cover 50-500hz? steve71 Multi-Way 13 17th January 2008 04:33 PM
Horn from 500hz to 20khz, how hard? bigwill Multi-Way 30 5th February 2007 05:10 PM
Copyright ©1999-2019 diyAudio
