Smallest Footprint Horn and Driver that can reach 500 Hz
Old 23rd September 2018, 07:24 PM   #181
EarlK is offline EarlK  Canada
Originally Posted by Ro808 View Post
@EarlK, which DDS horn is in front of the 802D?
It's this DDS CFD1-100 pdf
I'm listening to it , oriented in the vertical ( like Bear used to recommend ).
This is not a constant coverage horn ( by my definition ) / though it still sounds nice.
It's very shallow at 5" ( like many wave-guides this size ) / so it does have that going for it.
- Still, it's not a hip horn to own or talk about .
PS; FYI, I believe DDS is pretty dormant these days.
Old 23rd September 2018, 07:45 PM   #182
Originally Posted by Pano View Post
Thanks for that Earl. I also tried the splash tweeters and found them to be OK. I usually ended up playing them straight ahead, tho, out of guilt or embarrassment something.
I suspect that different people hear things differently. I don't get much, if any, spacial benefit from tweeters, more of a tonality benefit. Like warmth on strings.
These Fostex are bullet type tweeters so I feel it's necessary to point them away from me ( no matter what! ).
I do agree that the tweeter "splash" detracts some from the "front-to-back" imaging ( if that is what you implied ).
- Keeping that in mind I'll be working to reduce the tweeters measurable effects ( from say 5K to 10K ).
Here's an REW wavelet showing the relative strength of this tweeter ( relating to the Altec 802 ) and it's shortish time signature/echo ( it's only 18" from the back wall ) .
One thing I'll say is that this is the first time one of these Fostex has remained hooked up longer than 15 minutes ( now, going on about 7 days > so that's a record ).
Old 23rd September 2018, 07:55 PM   #183
Ro808 is offline Ro808  Netherlands
Just for fun: try the Celestion with this horn, if you haven't done this before.
It won't play as low as the Altec, but the results may surprise you.
On the other hand, it would be interesting to see the Altec behind this (very cheap) Celestion horn:
Old 23rd September 2018, 07:58 PM   #184
My experience with oldskool drivers is limited, but experiments by other diy-ers have shown these often don't go well with waveguides.
For this reason it's quite surprising the Faital Pro's appear to be an exception, as they have a conical adaptation horn. I suspect the phase-plug design is a key factor here.
Addition:
The shape (length and flare-rate) of the conical exit part also plays a role.
Old 23rd September 2018, 08:29 PM   #185
I guess you want a pic ( right? )
Here it is;
Smallest Footprint Horn and Driver that can reach 500 Hz-celestion-cdx1-1747-dds-cfd1-100-vertical-orientation-png
This is a Celestion CDX1-1747 which very closely traces the CDX1-1745.
These 2 models are just about interchangeable ( from a trace perspective ).
See ( the raw, unEQed curves on the PRV, 152i clone waveguide );
Old 23rd September 2018, 08:33 PM   #186
Pano is offline Pano  United States
Pano's Avatar
Thanks for the graph Earl. Very clear.
Old 23rd September 2018, 08:46 PM   #187
Worldwide, everyone seems to make that horn.
I bought it under the Sammi ( Korean ) banner 20 years back.
It offers nice ( on axis ) flat response with good lower end loading.
Altec compression drivers ( IME, being ancient designs ) respond best to horns with exponential curves ( like this horn ).
This is a horn ( perhaps ) best listened to in the vertical orientation ( a la Bear ) > I wouldn't use it in the horizontal orientation.
Here's an ancient trace;
This was done with an non-calibrated test mic / so the HF above @ 9K is about 3db too hot.
Old 23rd September 2018, 09:41 PM   #188
This confirms my expectations
Thank you for the plots!
The DDS is certainly not bad, the slightly rough top octave is probably caused by anomalies at the throat.
The original QSC 152i waveguide was designed to work with Celestion drivers. Your measurements confirm it.
The main difference between the Celestion CDX1-1747 and the CDX1-1745 is in the suspension/damping of the diaphragm.
Old 23rd September 2018, 10:26 PM   #189
Cask05 is offline Cask05  United States
Cask05's Avatar
Originally Posted by hornwannabe View Post
Hey Guys got some bad news.
I got scammed by the ones selling the Klipsch K510 horns...Getting a bit disheartened with this project but iíll pursue it when funds become available again.
Have you recovered yet? Did you ever see anything on your K-510s?
Chris
Old 23rd September 2018, 11:26 PM   #190
Pano's Avatar
I think I have a pair of horns like that, bought on close-out from Parts Express. I was going to use them the Peerless compression drivers, but never got around to it. Still sitting on a shelf somewhere. Nice to see measurements with other drivers.
Take the Speaker Voltage Test!
Smallest Footprint Horn and Driver that can reach 500 HzHide this!Advertise here!
Horn Help: 2" 400-500Hz Horn Justauby Multi-Way 6 12th October 2017 01:46 AM
Looking for a medium footprint ~6" driver back loaded horn design hugz Full Range 7 18th August 2016 05:42 PM
The smallest size compression driver and horn? Brisso57 Multi-Way 42 27th August 2015 05:24 AM
Can a single straight horn cover 50-500hz? steve71 Multi-Way 13 17th January 2008 04:33 PM
Horn from 500hz to 20khz, how hard? bigwill Multi-Way 30 5th February 2007 05:10 PM
Copyright ©1999-2019 diyAudio
