Hi guys,
i have been planning on 2 way active biamped bookshelf speaker as gift for my frnd.I dont have any prior experience in active bi-amping or much of speaker building anyway . I did make a passive 2 way bookshelf speaker 2 yrs back and some massive subwoofers which has been very enjoyable.
I have chosen the following material
1.Mid range Driver
Nominal Impedance = 8 Ohms
Resonance Frequency = 49 Hz
Power Handling {IEC-268-5C} = 50 Watt
Sensitivity (2.83V/1m) = 90 dB
Resistance (DC) = 6 Ω
Qms5.24
Qes=0.38
Qts=0.35
BL=7.17 T-M
VAS =11.64 Liters
2. Tweeter
Nominal Impedance = 6 Ohms
Resonance Frequency = 950 Hz
Operating Range = 1,500 Hz to 20,000 Hz
Power Handling {IEC-268-5C} = 15 Watt
Sensitivity (2.83V/1m) = 94 dB
Voice Coil Diameter = 25 mm
Former Material = Aluminum
Layers = 2
Voice Coil Wire =TypeRoundCopper
Magnet Material = Neodymium
Dome Material = Silk
Surround Material = Silk
Front Plate Type =Moulded Plastic
3. Amplifier either of the following LM1875 or TPA3116
4. 12db 2 way crossover 2000hz
I modeled the speaker box in winisd and got a box volume of 9L with port dimension of 5cm X 19CM for tuning of 55hz at power levels of 20W the port noise is below 17
any suggestions ?
regards
1.Mid range Driver
Qms5.24
Qes=0.38
Qts=0.35
BL=7.17 T-M
VAS =11.64 Liters
2. Tweeter
Layers = 2
any suggestions ?
regards
Hi Sekhar !
Listen, the thing to keep in mind is that your crossover is not independent of the driver responses. You will need t measure the acoustic outputs, including acoustic offset, before determining the appropriate line level crossover.
Fortunately, Bill Waslo has just added some active crossover components to his excellent XSim crossover simulator.
For a little more information, see here:
A Speaker Maker's Journey: Crossover Basics - Driver Response
Best,
E
Best,
E
