Weaker low-range response of 3-way speaker
Old 29th May 2018, 02:24 PM   #21
adason is offline adason  United States
adason's Avatar
Hi krasnypixel, its ok to apply small amount of smoothing to the raw data. Especially in overlay.
Old 29th May 2018, 04:55 PM   #22
lowmass is online now lowmass  United States
seems like a simple baffle step and mid/tweet pad down issue?
Starting with that 8" woofer at 87 db sens, depending on how narrow your cabinet face is it is likely you will want to have the response cut down somewhere between 3 and 5 db by the time you get to about 400hz. This can be done with your woofer crossover by increasing the size of the inductor.
So if you do this then your system sensativity is now going to be only about 84db. This will mean that your HiVi mid and the planer tweeter will need to be padded down to match the rather low 84db sensitivity dictated by the woofer.
This means the mid will need to cut by about 2 db and the tweeter will need to be cut by about 10db!
And this is assuming only 3 db of baffle step! it may be you will need 4 or 5 db wich means you start with an even lower system sensativity and you will need to pad the mid and tweet even more.
Now in the end once you get everything taylored so it sound "right" you will have a rather low sensativity system and one with a different power response than the two way you said you liked with that woofer. It will be like comparing apples to oranges in the sound and small changes in freq response and power response can radically change preception. You can get reference quality sound out of that 3 way you have their BUt it will be at the expense of having a low peak volume and perception of dynamics may not be their
I would have started with a larger and higher sensativity woofer for a 3 way like that. Maybe even take the Mid down to 350hz
Old 29th May 2018, 05:42 PM   #23
jReave is online now jReave  Canada
Exactly. That is well put.
What are the chances too that your 2-way is sitting in a bookshelf or up against a wall or on a desk or some such so that the 6dB of baffle step loss is avoided?
Here are some resources that might help you out:
True Audio Speaker Topics: Spatial Loading
True Audio TechTopics: Diffraction Loss
(also on this topic, see the pics below)
Box
Box
XSim free schematic-based crossover designer program - Techtalk Speaker Building, Audio, Video Discussion Forum
Man I wish these things were stickied somewhere.....
Old 29th May 2018, 08:53 PM   #24
the way to "rescue" this one is to add 2 more woofers.
Weaker low-range response of 3-way speakerHide this!Advertise here!
How is frequency response range measured? scorr14 Multi-Way 5 26th September 2017 11:53 PM
Modify earmuffs to be weaker & alternatives jedi34 Everything Else 3 20th March 2017 02:26 AM
MAS SPA-100 left channel weaker sound FPN Solid State 12 27th August 2014 08:13 PM
Full range response vs. receiver LP and HP-frequencies? Iwont Tell Full Range 1 20th July 2011 11:17 PM
frequency range response query pmarcouxx Digital Source 1 23rd July 2005 10:17 AM
