Does cabinet depth affect BSC roll off?
Or is it just cabinet width?
I'm wanting to modify and existing design (Kairos) to make cabinet shorter but deeper, keeping front baffle width and volume constant.
Could I run into issue with a thicker sounding lower mid-range? The Kairos will be high-passed above 200hz as part of a 3-way... I cant picture if the baffle loss at these frequencies is due to a full wrap-around/cancellation involving the entire cabinet, or only a function of propagation off the front baffle?
Thanks for the help.
B
