Isobaric questions.
Isobaric questions.
Old 19th March 2018, 04:07 AM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default Isobaric questions.
I'm looking at an isobaric multiway for my next project. Reasons for considering - the bass drivers (satori 9.5") are available in asia/arent crazy expensive, but they need a large box. They also look great flipped.
There is a choice of 8ohm 88db or 4ohm 91db. I'd like to use 2 pairs per side as in the sketches, and this shows 2 ideas. For system sensitivity and output, which wd be the best option? Also, what wd be the limit of crossover point (to midbass)?
Old 19th March 2018, 08:26 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
They'll both work the same, give or take. I'd use the left one up to around 200Hz, and the right you might get 400Hz. The left one gives you vibration cancellation, at the expense of the cabinet needing more space behind it.
If you went 3.5-way and moved the woofers up, you could probably use the left one with a 400Hz crossover point, too.
Chris
My work: www.grimshawaudio.com
Old 19th March 2018, 11:30 AM   #3
Chris
Thanks Chris. wd it be better to parallel series the 4ohm version? Not sure what figure I'd end up with inc floor support
Isobaric questions.Hide this!Advertise here!
isobaric X 3 Discopete Subwoofers 6 19th December 2017 10:01 AM
Isobaric ESL Discopete Planars & Exotics 3 14th January 2017 03:42 PM
Isobaric JBL/RCF 18's mclsound Subwoofers 9 30th September 2012 11:21 AM
isobaric keyser Subwoofers 9 9th December 2010 01:35 AM
4x isobaric Jennice Subwoofers 42 17th May 2005 07:42 AM
Copyright ©1999-2019 diyAudio
