Crossover/Speaker Design Questions
Old 18th March 2018, 04:51 PM   #1
BennixD is offline BennixD
Question Crossover/Speaker Design Questions
Hey guys,
right now Im starting a new Project. My aim is to build a new passive Reference-Monitor. As of right now I started designing the crossover and Speaker and would love to get your opinion and Feedback.
This is how it Looks right now.
Monitore 2 Wege - Album on Imgur
For the Amp I want to use this one:
the t.amp PM40C Endstufenmodul – Musikhaus Thomann
Could that project work? I know nobody can surely say it will work, but I want to know if my concept makes sense/has potential...
The Box has a total volume of about 14 litres and I want to uild in a BR with 1,5" Diameter and 6" length. (Thats what the Woofer Descr. suggests, With that I will get a res at 50hz and that will hopefully work against the last dip at around 50Hz and clear it a bit up)
Just want to get some opinions before I start Building it. I know simulations are only approximations....
Thanks in advance Benni
Old 18th March 2018, 05:36 PM   #2
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Hi, it doesn't say anywhere what these drivers are and what you did with frd/zma files.
A reference monitor would probably deserve a reference amplifier and this amp of yours does not look like one. I would look for a good deal on class ab, classic 3 stage design topology.
Old 18th March 2018, 05:43 PM   #3
Its in the Link with the Pictures. You can See the crossover there
Old 18th March 2018, 05:54 PM   #4
Lojzek's Avatar
I am awfully sorry, I still can't seem to find the info I was reffering to. Do these drivers have a name and model?
Old 18th March 2018, 06:02 PM   #5
Woofer is: SB17MFC35-4
Tweeter is: SB Acoustics SB26STAC-C000-4 1"
I can also send the link privat with the crossover
For the FRD and ZMA Files I needed to pull them with FPGraphTracer.
Then I started (like in the Picture) to work with them and try to design a simple crossover with a good freqeuncy Response.
Benni
Old 18th March 2018, 06:11 PM   #6
Lojzek's Avatar
Thanks, I'll do a sim of my own and the next day I'll tell you what I think of it.
Old 18th March 2018, 06:14 PM   #7
Really appreciate your Input!
Would be great!
Maybe you can also simulate my Crossover and see if it works?
Would be a huge help!
Would love to know if my concept might work and If it could then I will immediately start building it!
Thank you Benni
Old 18th March 2018, 06:16 PM   #8
I would really appreciate it!
Maybe you can test my crossover too and simulate it and tell me if it works !
If it could work I definitely will start Building it !
Thanks in advance Benni !
Old 18th March 2018, 06:22 PM   #9
Lojzek's Avatar
Yes, that was the general idea, otherwise it would not have made any sense. These drivers are as if I have picked these out myself, not too expensive yet with great potential, great enough to be called reference ones, IMO.
Old 18th March 2018, 07:02 PM   #10
Lojzek's Avatar
There is an obvious error with tweeter zma of the raw driver from your XSim snapshot. Correct the tracing to look like a 4 ohm unit by entering the top value on y-axis as 16 ohm, not 160 ohm.
Crossover/Speaker Design QuestionsHide this!Advertise here!
Low pass crossover design questions. Old'n'Cranky Multi-Way 11 12th May 2017 09:41 AM
Speaker Design Questions BasicHIFI1 Multi-Way 23 9th March 2016 05:05 PM
Crossover design questions shmb Multi-Way 12 28th December 2012 02:57 AM
Buidling my first speaker system but I have crossover questions m11a1 Multi-Way 21 17th December 2010 06:52 PM
DIY Leslie speaker cabinet crossover questions dfro Multi-Way 6 30th May 2006 06:22 AM
Copyright ©1999-2019 diyAudio
