My OB Project
My OB Project
Old 9th April 2018, 01:08 PM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I'd just hand twist what's there . Thanks for the link
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 11th April 2018, 09:58 AM   #12
hazard500 is offline hazard500  Australia
Originally Posted by Elemental View Post
Thanks for sharing your OB Project, I bet they sound fantastic! I pretty much followed your same path – at an audio show last fall I heard the Pure Audio Project system and was blown away with the clarity and purity, and its simplicity.
My research lead me to the OBL-15 too and choosing the FP 15PR400 for the bottom end, though I’m only using one per side (couldn’t imagine needing a second-must be impressive!). I chose the MarkAudio 12P for my mids (full range) and so far don’t hear a need for a tweeter, time will tell once “broken in” and design finalized.
“At my age”…(I got frustrated with the free on-line design programs) I didn’t do a lot of design simulation or pouring over spec’s and numbers, but more of a “seat of the pants” design approach. Inexpensive plywood and experimenting with what “sounds good” is my design tool.
My system will be bi-amped so one “high-tech” gadget I sprung for was the MiniDSP as an active crossover. An awesome tool and very easy to setup and use, allows me to play with different crossover points and EQ.
Did you do any dampening or treatment to the back side of your baffle? I’ve heard some builders do that but haven’t tried any myself.
Thanks again for sharing and enjoy your speakers… Dave
Hi Dave, have you posted any pictures of your system on the forum? Mark Audio drivers were on my short list before I found the Boyd drivers, I bet they sound fine.
With regards to damping of panels - I have given a little thought to this but I have a few other projects I need to attend to first. On thing I might try is building a sand box in the bottom of the cabinet. The base of the cab is 600mm by 600mm, and loses about 75mm on the front and similar on sides due to wings. I could pour about 1 or 2 inches of sand in there, and would need to find a way to keep it from blowing around but that should help with vibration (not that I can feel a lot of vibration in the front baffle). In an ideal world with unlimited time and funds and better woodworking skills I would build another cabinet with sand filled baffles but that is probably not gonna happen.
Old 28th May 2018, 04:42 AM   #13
hollowboy is offline hollowboy  Australia
Originally Posted by hazard500 View Post
On thing I might try is building a sand box in the bottom of the cabinet. [...] I could pour about 1 or 2 inches of sand in there, and would need to find a way to keep it from blowing around
Probably easier to keep the sand in containers (coffee sacks / pillow cases / stuffed owls / whatever) rather than have it loose. Especially if you'll ever cat sit for a friend.
A 20kg sack of rice will work just as well as a 20kg layer of sand, and will be a lot more handy during the next zombie outbreak.
This edit signature thingy is seriously hard to find
My OB ProjectHide this!Advertise here!
The BiAmp (aka My LM4766 + 6p15p project, and LM1875 project.) valtra103 Chip Amps 21 4th December 2015 09:32 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 05:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 02:39 PM
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 12:37 PM
