Problems with impedance measurement
Old 12th September 2018, 07:11 PM   #41
Aucosticraft is offline Aucosticraft  India
More help on mod.
NwAvGuy: Behringer DAC Modifications
There is always a first time....
Old 12th September 2018, 07:45 PM   #42
Found one more.
Behringer UCA202 / UCA222 USB Soundcard Headphone Improvement: 8 Steps
Old 12th September 2018, 08:50 PM   #43
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by bentoronto View Post
I'd rather be quick and dirty if it gets the information I need in a trustworthy manner.
Sorry for the slow response, but... is this supposed to be a joke?
Do you check the code line by line?
Actually, yes. First I write the code, then I check my work.
It is possible to verify that the software seems to be working like it should and doing so is good practice. But that just adds one more layer of elaboration.
Uhm, is this another dimension of your joke above? Don't you test things to make sure the software (and everything else) is set up correctly and works as it should?
Support the Monkey Coffin!
Old 13th September 2018, 01:12 PM   #44
ctrlx is offline ctrlx  United Kingdom
have you guys tried using an amp in your setup?
do this first instead of modding the soundcard.
see post 12
Old 13th September 2018, 07:53 PM   #45
Mario Pankov is offline Mario Pankov  Europe
see post 12
Thats a diy audio forum. So...why do it the easy way?
Old 14th September 2018, 07:26 AM   #46
see post 12
Currently I am not trying to achieve power. I need this card for driver TS measurements.
And if the output is pre filtered ( with the RC ) the power amp is not going to help. We need impedance curve flat deep down to 10Hz at least.
Old 14th September 2018, 07:41 AM   #47
see post 12
Probably what you said makes sense. I simulated it. and if we use high input impedance amp it should solve the problem.
Old 6th December 2018, 08:46 PM   #48
Some looooong time later I`ll dig this one up. Here is a measurement done on a standard wirewound resistor using a proper audio interface (USB powered Komplete Audio 6). You can see the differences to the Behringer.
Old 7th December 2018, 01:32 PM   #49
Modified Behringer, right ?
Yes it gives good results. I too will post soon when I get time.
Old 7th December 2018, 03:00 PM   #50
celef is offline celef
There is an internal crosstalk in the behringer uca202/222, to work around this i use two, one for the output and one for the input - works great!
But even better with um22 as output since it can do higher levels of output
Problems with impedance measurementHide this!Advertise here!
Liberty IMP Impedance Measurement Ardee Multi-Way 22 6th June 2009 01:47 AM
Impedance measurement jig for SpeakerWorkshop Tenson Multi-Way 10 24th November 2007 11:56 PM
DC Source Impedance measurement hugeli60 Solid State 7 13th February 2004 04:07 AM
Impedance measurement Doug Everything Else 2 9th August 2003 05:50 AM
Vifa Impedance Measurement. Dave Multi-Way 27 2nd December 2001 02:55 AM
