Little yellow cab ? (monacor sph-200ke+ dt-254)
Old 1st March 2018, 12:49 AM   #1
00940 is offline 00940  Belgium
00940's Avatar
Default Little yellow cab ? (monacor sph-200ke+ dt-254)
Any opinion on this design ? Little Yellow Cab – Donhighend Audio It's in German but google translate doesn't make too bad a job
Strong 8" in a sealed cab + a 1" tweeter on a waveguide. About 160 euro per speaker for the drivers and the crossover parts.
I need monitors for a medium sized room and I'm really tempted to start the build, with all black mdf. Any reasons not to ?
All that is excessive is insignificant. Talleyrand
Old 1st March 2018, 11:47 AM   #2
Mario Pankov is offline Mario Pankov  Europe
Pretty well designed, don`t make the build price fool you - this will be a very good loudspeaker. The kevlar Monacor drivers have fantastic low end extension in small cabs. I didn`t know the DT-254 fits the WG300. You can do even better with the DT300 but it requires a different crossover and has a dip at 15Khz (not a big issue).
Old 1st March 2018, 12:06 PM   #3
kec is offline kec  United States
kec's Avatar
Looks like a black cab to me
Former Altec Employee ('78-'82)
Old 1st March 2018, 01:05 PM   #4
00940's Avatar
@ Mario: yes, the kevlar Monacor look very good on paper. It's good to know they also work in practice. I'm surprised they aren't more commonly discussed.
Actually, I found that webpage by searching what was available for the sph-200ke. Notax had suggested a combo sph-200ke+ dt-28n in this thread. But this is fully detailed and the size looks right for me.
The designer also has a big floorstander with the same tweeter but the sph-250ke. Initially, it used the xt25 as tweeter but found the dt254 less strained.
There are some nice designs on that website. The small 2.5 way called the quintessenz could be a future project.
Old 1st March 2018, 01:27 PM   #5
Paul Vancluysen is offline Paul Vancluysen  Belgium
It is a very well done design and it will perform also very good, no doubt about that.
I have one consideration concerning the low frequency response and the overall sensitivity.
This Monacor woofer has a basic sensitivity of 87.5dB @ 1m, 2.83Vrms on infinite baffle (calculated with TSP).
The closed box design has about a F3 = 55Hz ( in 17L ).
To realize a flat SPL in full space (anechoic room response) with a F3 = 55Hz, the overall SPL should be designed to about 81.5dB.
Now the overall sensitivity seems to be 85dB. So in full space the SPL is 6.5dB down at 55Hz.
So this design seems to have a slow roll off to low frequencies. Maybe it will perform well in a room, no discussion about that.
Personally, I should prefer to make the design flat in full space with a F3 = 55Hz and a overall sensitivity of 81.5dB. But again, this is a choice I should make for it.
Regards, Paul
Old 1st March 2018, 05:54 PM   #6
The SPH-250KE has all the ingredients to deliver strong bass fundament from a small box, mids comparable to the midrange reproduction of a speaker intended for public transport and will start to become directional so low that without a large waveguide to match directivity, you`d approximate the Klingon mothership Bird of Prey, basically the one that can destroy Earth with two shots, when you measure the final speaker`s off-axis response. Pairing it with a tweeter like the XT25 is even more...well you get it.
Old 6th March 2018, 10:24 AM   #7
peterbrorsson is offline peterbrorsson  Sweden
Regards, Paul
Hello Paul,
My German is not the best but it's a GHP (Geschlossen mit Hochpass) Bass driver is high passed with 470-680µF making it I guess-3db slightly under 40Hz.
I use GHP with Visaton AL170, it moves -3db from 65Hz to 50Hz and flattens the bump (due to smaller box) around 100Hz also. I just followed Hobby Hifi's Visamon 170 box volume...
Peter
Old 6th March 2018, 10:45 AM   #8
Hi Peter,
Yes, of course with the capacitor the low frequency response is different. I didn't remark the value of this capacitor, in the schematic it is labeled 0.0 F .
Thanks for your feedback.
Paul
Old 6th March 2018, 12:54 PM   #9
00940's Avatar
The German DIY scene seems to like those "GHP" designs. I've noticed this one, with similar drivers : Strassacker: Speaker Building, Components
It's quite a bigger box though.
Old 6th March 2018, 03:51 PM   #10
Mario,
In Brno's public transports, it doesn't matter if one is Swedish, Kenyan or Czech, next station could be Rome or Montevideo concerning the audio quality...
Little yellow cab ? (monacor sph-200ke+ dt-254)Hide this!Advertise here!
TSE : inverting red and yellow cable gmonno Tubelab 3 9th June 2013 06:21 PM
FS or Trade: Monacor SPH-200KE 8" mid woofers gaborbela Swap Meet 4 25th October 2011 06:46 AM
FS: Green/Yellow LED's max426 Swap Meet 2 5th December 2009 02:15 PM
PS-3 The Yellow Light of Death !! poynton Everything Else 1 18th November 2009 05:33 PM
Copyright ©1999-2019 diyAudio
