Open source Waveguides for CNC & 3D printing!
Old 3rd February 2018, 02:30 PM   #21
natehansen66 is offline natehansen66  United States
Gaga, could you post the ABEC files for this sim? I've made pretty good progress with ABEC but I've hit a road block that I think may be due to my old pc. I'd like to try to run this and see if it works.
Old 3rd February 2018, 08:55 PM   #22
Gaga is offline Gaga  Europe
Nate, I'll post the project here or give a download-ling via PM. It will need some time, as I have to clean up the scipts - I did not have in mind to share, when setting up simulations for these waveguides.
BW, Christoph
Old 5th February 2018, 10:30 PM   #23
Rokytheman is offline Rokytheman  Denmark
Originally Posted by augerpro View Post
No I haven't. Are the diaphragm dimensions the same as the TW29RN?
Not sure if the dimensions is exact the same. The piston area on both tweeters is 9,6 cm^2. The normal holes for mounting the tweeter (with faceplate) is quite close.
Of course the two tweeters are not the same, but maybe a waveguide for the Satori-tweeter will work okay for the SB29.
Last edited by Rokytheman; 5th February 2018 at 10:34 PM. Reason: adding more information
Old 10th February 2018, 01:50 PM   #24
Default Phase Shield
Early on in the thread at PE, we discussed this, and it would be fairly easy to design the phase plug as a standalone item with cylindrical keys at the end, with a matching depression in the waveguide wall which would be easily made with the end mill of the CNC. I "hope" with some optimization the phase plug won't be necessary.
I did some simulations with 3 different phase plugs. I think that the specific design of phaseplugs/phaseshields for a waveguide is a very good tool to achieve (as good as possible) constant directivity up to the high frequency range.
Reason is that a 1''-membrane already starts to beam >6kHz. This simulation (done using AxiDriver) shows a 25mm membrane in an infinite baffle (with SB26 TSPs):
and the respective directivity plot (normalized to 0):
Now, where do 'phase-shields' (often seen as small, round, transparent plastics fixed at the back of protecting grids in front of metal domes) impact the directivity of dome tweeters?
This is a simulation of Brandons eliptical waveguide 'C' with a small phase-plug V1:
The respective SPLs from 0-90, 15-steps, normalized to 0:
The same for a phase-plug with higher diameter:
SPL 0-90 (as above):
And a phase plug version 3, a ring with central hole:
Again the directivity 0-90:
Where does the phase plugs impact directivity? As a comparison, the directivity 0-90 of the waveguide without phase plug vs phase plug V2:
For better comparison the horizontal directivity without phase plug:
The effects of the phase plugs appear around 13-20 kHz, where the WG-contour has no effect (may be beside bad match of tweeter membrane and WG-throat).
The suggested phase plugs are not meant to be the best possible solution here, they should just help to demonstrate the impact of phase-plug variations in this waveguide.
Before performing more simulations of different phaseplugs, I'd suggest to start with the WG-contour instead, if you're interested.
BW, Christoph
Old 10th February 2018, 03:17 PM   #25
Ro808 is offline Ro808  Netherlands
Christoph, your conclusions with regards to the phase plug are valid, based on experiments with optimization of horns by Scandinavian scientists. They found the impact of a phase plug is significant in the highest octave (albeit with some transmission losses).
I'm currently trying to replicate a similar setup but this will take a while (or even a long time ;- ).
Some optimization functions are available in Comsol, based on earlier work done by the Scandinavians. They have published more advanced methods recently, but:
- these involve a lot of scripting complex math in Matlab
- and might be overkill for this project.
Old 10th February 2018, 07:18 PM   #26
augerpro is offline augerpro  United States
BW, Christoph
I agree.
BTW I did some comparisons of phase shield shapes back in the PETT thread, but photobucket pulled the pics Anyway, I did four shapes: disc, cone (like Vifa/Scan), scalloped disc, and a ribbed plug similar to the ones Eton uses on their woofers. They were all terrible except the disc and scalloped disc. The scallops offered no advantage, so I further investigated the simple disc. I tried diameters of .5", .38", and .25". The .25" offered the best balance of properties.
I was curious about the ring type you simmed, since this is pretty common. I never really understood it, why only allow the parts of the membrane furthest from each other to radiate? And your sim reinforces my intuition. (maybe with a fabric dome this could work where the center of the doming is moving out of phase with the outside, but with the geometry involved puts the radiated sound back into phase at any typical listening axis).
I should be able to get measurements of the new waveguides taken tomorrow.
~Brandon
DriverVault Soma Sonus
Old 10th February 2018, 07:52 PM   #27
Interesting!
I did simulations to compare the impact of a simple 'disc' vs a 'ring-type disc' in the waveguide thread here. Diameter and placement of the 'disc' and 'ring' were identical.
Here, the ring had a positive impact in that it resulted in a more constant directivity between 15 and 20 kHz.
Simulations done using AxiDriver. Disc phase plug in front of SB26 dome:
Directivity -90 to 90, normalized to 0:
Note the 'widening' aroud 17kHz.
Same simulation with 'ring' phase plug:
Directivity, normalized to 0:
The 'widening' smears over a larger frequency range and shifts to higher frequencies, resulting in a more constant directivity.
Note that AxiDriver (and ABEC) assumes an ideal membrane without break-up at higher frequencies. Simulation of fabric domes is therefore not really possible. Simulation of metal domes is (hopefully) more realistic though.
Old 10th February 2018, 09:53 PM   #28
Your disc diameter is close to .5" which I found to be inferior to a smaller one - though I haven't looked at the plots to see if they match your sim. Try a .25" diameter disc and see how that sims.
~Brandon
Old 10th February 2018, 10:23 PM   #29
Version 1 shown above is the phase shield with a diameter of 0.25'' as you suggest.
Version 2 has a diameter of 0.56''.
Version 3 has an inner diameter (hole) of 0.318'' and a ring of 0.127'', i.e. a diameter of 0.572''.
May be I should have given the diameters of the simulated phase shields....
BW, Christoph
Old 11th February 2018, 12:10 AM   #30
Doh, I knew that, sorry!
~Brandon
Open source Waveguides for CNC & 3D printing!Hide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 02:31 PM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 03:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 02:21 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
UK source for Waveguides for tweeter (or how do DIY one)? Puggie Multi-Way 3 22nd June 2005 04:55 PM
Copyright ©1999-2019 diyAudio
