Open source Waveguides for CNC & 3D printing!
Old 6th December 2018, 02:36 PM   #281
Mayuri is offline Mayuri  Finland
Mayuri's Avatar
With the test versions I've printed, the phase shield is always printed faulty. Decided to remove it in the end, because at least on the 4" version it makes a minimal impact and it's much easier to print without it.
If you are having problems with flush mounting elliptical waveguide, just make it have a round base with some free CAD program, such as TinkerCAD.
Old 6th December 2018, 08:36 PM   #282
Bear5k is offline Bear5k  United States
Originally Posted by augerpro View Post
Not sure what you are asking for regarding a flat surface? The face the tweeter attaches to has some centering pegs which could be optional and a sealing lip which is not.
Sorry. Apparently I wasn't clear. I'm talking about the, uh, business side of the waveguides. Your testing has shown a circular jig/mount into which the elliptical waveguides have gone.
If I were mounting the 6" on a baffle, I'd like to be sure that the major axis is perpendicular to the vertical edge of the baffle (Y-axis) of the baffle. Looking at the template-making instructions on the Reddit link, below:
Step 2 - Creating X and Y coordinate lines is straightforward. I can probably eyeball the long axis using the side screw holes. Index marks on the back of the waveguide would be valuable to align the X and Y axes of the waveguide to the X and Y axes of the disposable first template.
Step 13 - this translates the patterning to the baffle, but it will also translate any initial positioning error (e.g., if the waveguide was canted 5 degrees when the first template was made, this is what would be transferred to the baffle).
Index marks on the back of the waveguide (voids, rather than protuberances would probably be easiest) would help align the guide. A flat surface, 90 or 180 degrees for an inch or so, would also help with alignment using a square (e.g., carpenter's, framing). Think of it like truncating a driver frame, but it doesn't have to be on the face of the WG (though that is easiest.
These are easy to make a routing template for: Tutorial: How to flush-mount irregular shaped speakers : diyaudio
Thanks! I just re-read the thread and picked up on that. I'll just take the brute-force template approach, rather than trying for a generalized solution for ellipses. I'm not sure why using template making techniques isn't already in my go-to arsenal, but I'm sure it soon will be. Also, this is the upside for having spare junk parts. I don't have to worry about hurting them cosmetically. :-)
Old 6th December 2018, 10:02 PM   #283
On further thought, if I drill the mount holes first, rather than using the waveguide as a locator for my punch, then I should get it oriented close-enough to square so that I won't notice.
Old 12th December 2018, 04:47 PM   #284
joetekubi is offline joetekubi  United States
Hey Brandon -
Have you done any modeling or fabrication for ribbons or AMT tweeters?
I've got some Airborne AMT tweeters that should work great in a WG, but no commercial product seems available.
If there is a model, I've got a friend with a 3d printer that has offered to print me some.
Old 12th December 2018, 06:14 PM   #285
augerpro is offline augerpro  United States
I haven't, but if you get me the relevant measurements I can see what I can come up with.
~Brandon
DriverVault Soma Sonus
Old 12th December 2018, 09:49 PM   #286
I'll provide physical measurements to the best of my ability.
Next few days....
Old 13th December 2018, 09:15 PM   #287
Brandon,
here is what the Airborne 4001 looks like, and I measured the dimensions as best as I could. No hurry on any sims, but I will try to respond quickly if you need more info.
THANKS!
Old 13th December 2018, 09:47 PM   #288
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by joetekubi View Post
Hey Brandon -
You might like this:
Ribbon Unity Horn
Old 14th December 2018, 12:35 PM   #289
Cool project!
~Brandon
Open source Waveguides for CNC & 3D printing!Hide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 03:31 PM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 04:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 03:21 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
UK source for Waveguides for tweeter (or how do DIY one)? Puggie Multi-Way 3 22nd June 2005 05:55 PM
