Open source Waveguides for CNC & 3D printing!
Old 14th September 2018, 08:39 PM   #151
augerpro is offline augerpro  United States
You have to consider the surround diameter also, since that is what sets the throat diameter.
I don't know why some tweeters do well and others not. Like that 833000 on a round wave guide. I have some ideas though, I think I'm going to revisit using a partial ellipse for the profile of the wall.
~Brandon
DriverVault Soma Sonus
Old 14th September 2018, 09:05 PM   #152
burgunder is offline burgunder  Denmark
Is the SB26ADC supposed to be used with its own faseshield?
Old 14th September 2018, 09:29 PM   #153
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Take a look at the Sd specs, which should take into account half of the surround. The 833000 Sd is 8cm, the 6640 Sd is 7cm. This suggests the diameter of the 6640 is less than that of the 833000. But that's just hand waving... I'll have to put that waveguide on my 6600 and see for myself how this works.
Support the Monkey Coffin!
Old 14th September 2018, 09:32 PM   #154
Gaga is offline Gaga  Europe
I think I used a Mac-based speaker measurement software you developed many years ago... nice to meet here.
I actually prefer Be dome tweeters like the ScanSpeak 6640 or the Satori TW29BN. From screening this thread I tend to believe that those tweeters don't play well with (custom?) waveguides. Is that correct? Why? What makes a tweeter a good tweeter for waveguides?
Well, not easy to answer. Some issues here (disclaimer - with quite some speculations): Mechanically it's about the adaption to the WG-throat, i.e. is the front plate of the tweeter plane or rounded around the dome? Can you remove the faceplate ('Zwangszentrierung') to fit the dome tho the WG-throat? A good fit of the dome/surround to the throat. With a custom WG that's just by chance.
A second criteria might be the directivity of the tweeter at high frequencies. A higher directivity tends to minimize interaction with the WG throat which help to get a smooth high frequency range. That might be the reason, why ring radiator tweeter often work well with custom waveguides.
And I'll definitely second augerpro: the diameter of the tweeter (including surrounding).
As you are familiar with German language, you might be interested to take a look at the thread on 'how-to constant directivity'-thread at the German DIY-hifi-forum - quite some information here. Some of the simulations indicate that it might be beneficial, if the tweeter membrane is perpendicular to the WG throat (even if it needs to implement a 'step' at the WG-throat to achieve this).
Bottomline: It's kind of tiral and error to ideally match a tweeter to a custom WG - or you construct the WG to a specific tweeter
Old 14th September 2018, 09:34 PM   #155
You can put off the faceplate of the SB26ADC and mount the dome directly to a WG.
Old 14th September 2018, 11:06 PM   #156
Thx I forgot that you have to remove the faceplate to mount the tweeter on the waveguide.
Old 14th September 2018, 11:21 PM   #157
This is exactly what I was thinking and why wanted to revisit the ellipse as profile. I can be steep (90 degree) at the dome, but than smoothly transitioning to the baffle.
~Brandon
Old 14th September 2018, 11:24 PM   #158
I wish SB would just release the Be version of the SB26 they are making for Revel!
~Brandon
Old 15th September 2018, 02:38 PM   #159
mbrennwa's Avatar
Oh, wow, that was a looooong time ago!
I had a look at that thread, which seems interesting. However, the figures don't show and it's a bit difficult to understand what you did without the figures.
Old 15th September 2018, 06:26 PM   #160
Ah yes, sorry, you would have to register. I can post some relevant info and images here, if augerpro does not mind...
Open source Waveguides for CNC & 3D printing!Hide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 03:31 PM
Ultimate Open Source XMOS USB-I2S: The source to end all sources. krfkeith Digital Source 4 14th June 2013 04:54 PM
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 03:21 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
UK source for Waveguides for tweeter (or how do DIY one)? Puggie Multi-Way 3 22nd June 2005 05:55 PM
