Some speaker driver measurements...
Taken from the CSS website..
Linear Distortion
The first and most prevalent type of distortion is linear distortion. Linear distortion is distortion in the frequency response. When we perform a sinewave sweep from 20 Hz to 20 kHz, the input signal is actually providing the same driver level at all frequencies in the sweep. This means that in an ideal world, the speaker would output a flat line from 20 Hz to 20 kHz, or in effect, it would reproduce the input signal exactly. However, in the real world this doesn’t happen for a variety of reasons, especially when we look at individual drivers. Deviations from the ideal flat line are considered linear distortion. This article isn’t going to focus on the argument of whether or not flat frequency response is best. That is outside the scope today, but what is definitive is that the more a speaker deviates from the ideal straight line response, the more linear distortion it has.
If you are asking which of the two speakers sounds better personally for me, my answer is no one. It's not compare like apples to apples, because the descripience in their sizes - 34cm2 vs 58cm2. The PL11MH sounds a little bigger, the 3-212 is more spacious. The both have a pleasant a warm sound signature.
